Armwarmers ...
Bikes: 2009 Trek 1.2
Quoted: 239 Post(s)
Armwarmers ...
do they really help?
Was chilly and still breezy last night, was in shorts and short-sleeve jersey, and it was just enough to be a little uncomfortably chilly, but not cold enough to layer up, etc.
I don't want to go with long-sleeve jerseys, but would consider armwarmers if they really work.
LET'S ROLL
They work for me, been using them for a few years now.
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
not as fat as I was
Bikes: Trek 7000, Trek 5500, Fuji Newest 1.0
Yep....they work. You can also use a light windbreaker to do the same thing.
humans can be so....rude
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
I really like these things. Cheapo Under Armor type under layers from Target (Champion C4/thinner model) and Walmart (Starter thicker model). About $12.
Thick enough to keep the cold off your arms but light enough so that I can use them on a warm day on the climbs to keep the bugs away. I've used them on 80 degree days on the climbs. I've always hated long sleeves in anything but nice once you settle in these things, it's like a second skin.
Can't lose for $12 vs the $25 for arm warmers.
Quoted: 239 Post(s)
Beanz that's what I usually do ... a thin, wicking type layer underneath ...
but when I get warm, I'd like the option to push the sleeves up, or down, provided they were armwarmers
Starting over
Bikes: 1990 Trek 1500; 2006 Gary Fisher Marlin; 2011 Cannondale Synapse Alloy 105; 2012 Catrike Trail
Quoted: 10 Post(s)
I just got my first pair last week. Nashbar had their house brand ones on sale for $15. I wore them for the first time in the wind on Monday's ride. I thought they were great. We'll see how they hold up to wear and washing (my wife put them through a dryer cycle without realizing it).
Edit: I just checked and they're still on sale. But they also have some Cannondales for the same price, and some Descentes for only $5 more.
Quoted: 18883 Post(s)
Liked 10,646 Times
But I have a few pairs of arm, leg, and knee warmers, too. Mine are all home made, from merino and from cashmere. I really like the cashmere ones. Their warmth to weight ratio is superb, and so they pack down to almost nothing. I can enjoy the heat of the day, but stay toasty when the sun disappears behind the mountains, even if I'm on the salt water.
A square going nowhere
Bikes: CAAD 8 & CAAD 10
Love my arm warmers, usually in the morning. As it warms up, I can pull them down while riding, and stuff them in my pocket when I stop. I bought a pair of nashbar warmers about 5 years ago, still in great shape.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
Wonder if arm warmers would help keep arthritic joints warm enough to stop hurting?
This is the time of year here in the midwest that can get very painful for me.
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Keep in mind, they come in two styles, so know which you're getting or want.
One is just a plain lycra arm-warmer. Helps on slightly cool days. Some have fleece inside (called "therma-fleece" by somebody) that helps on colder days.
When it gets into the 40's and below, I'll wear arm warmers and a jacket.
great as an extra layer without having to carry an extra jersey, ditto leg warmers too..
Quoted: 239 Post(s)
REI has some made by Novara that are fleece lined ... think I"m gonna grab a pair today
2nd Amendment Cyclist
Bikes: Schwinn 2010 World Street, Handsome Speedy w/ SRAM Apex
Last winter I commuted with a combination of the following:
long-sleeve 'tech' (read: polyester + spandex) compression shirt
Short-sleeve jersey and/or short sleeve loose-fitting technical T.
fleece jacket
nylon shell cycling windbreaker w/waterproofing.
Bottoms:
Leg warmers
bibs
nylon shell waterproof pants
That got me riding in temps down to the 20's.
Layering is good. The biggest problem with a long-sleeve baselayer and a short-sleeve jersey over it was all day rides where I wanted to remove the long-sleeve jersey about 1/3 of the way through, then wanted to put it back on again as it started to get dark. Arm warmers would work well for that (or rather, arm warmers + a vest, or a technical fabric jacket)
fleece jacket
Bottoms:
Leg warmers
bibs
Quoted: 4234 Post(s)
Liked 2,949 Times
I don't like the quality of the walmart "starter" brand technical stuff. The compression stuff is ok, but the seams are poorly sewn and they tend to rip on me. For as cheap as they are though, they make a decent base layer. The "moisture wicking" t-shirts though are a huge waste of time as a base layer. Hot and hold onto the moisture as if they were cotton. Wore them a couple of times this summer (just to make sure it wasn't a fluke) and the base layer clung to my skin all soaked and the jersey over the top was more or less dry.
If the sewing weren't so crappy, I'd get more of the compression stuff from there though.
I got a couple of sets of both nashbar arm warmers and leg warmers on sale in the $8-10 range and they work pretty well on the days that it's quite cool (say 40's or so maybe upper 30's). Any higher than that and they're just too warm for me. Would like to get a lighterweight set for rides in the 50's that look like they're going to warm up later in the day when I'd take them off. I do have a lightweight full zip long sleeve jersey I use in that range now (and the starter compression long sleeves), but would like a lightweight armwarmer.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Liked 2,949 Times
I don't particularly like the grippers on the nashbar stuff though. They dig in to my upper arm a lot more than is comfortable.
Bikes: 2011 Globe Daily 2 men's small
I don't like arm warmers, but mostly because I'm kind of funny about tight stuff on my arms.
I prefer to take along a really light poly shell jacket. I can leave it unzipped and tuck it into my center jersey pocket when just my arms are cold, let it hang down my back when it is a bit cooler, and use various zip-levels as I need as it gets colder or rainy.
More versatile.
And you never lose one-arm somewhere on the side-of-the-road when you take it off during a ride...
More versatile.
train safe
The best buys I ever made for spring/fall riding are arm warmers, knee warmers and a vest. The combination is awesome, and you can use as much or as little as you want. Obviously if it is going to be wet as well, you want a jacket of some kind, but knee warmers and arm warmers have stretched my 'shorts' riding weather substantially.
Check Longscycle for great sales on arm warmers-- they sell some made by defeet (the same people that make the socks) and they allow you to roll them to your wrists when it gets warm, rather tahn pulling them down and having them bunch at the wrists. When you take them off they look like cloth donuts.
train safe-
train safe-
Went for a ride yesterday using my new arm warmers I picked up online, it was about 45 degrees not bad - https://longscycle.com/product/microf...x-arm-warmers/
Bought these around Christmas time for 24.99 and they are on sale today for only 19.99 - totally worth the money - love these things!
Bikes: 2006 Specialized Ruby Pro aka "Rhubarb" / and a backup road bike
Quoted: 7 Post(s)
Liked 13 Times
I usually wear a thin mesh baselayer top for that transition zone where summer gear is too cool (low 50F).
Most of my rides where there is a significnt climate change I'll be making a pit stop where I can peel off a layer and stuff it in a drawstring backpack.
Not built right for armwarmers/legwarmers, they either pinch at the top or are too tight at the bottom, or slip and bunch (too long).
Bikes: Bacchetta Giro 700C, Rans Seavo tandem, Giant OCR-2 & a Specialized Rockhopper
+1 on arm warmers and leg warmers.
Of course my wife and I are riding in North Texas so cold is kind of a relative thing here.
Arm warmers and leg warmers give us the ability to regulate our warming/cooling as we ride. This time of year, an early Saturday morning start can be around 36-40 degrees, by noon, it can be up to 65-70 and sunny. It's nice just being able to shuck out of the warmers and stuff them in a pocket or bag without having to deal with the bulk of a jacket and tights.
Semper Fi
Semper Fi
