Ask Scrod
#3526
Your cog is slipping.
I lived in the Coronado District and was one of the few white people in my 'hood. Little kids would literally walk around selling fresh tamales out of an Igloo cooler on weekends.
For the most part, Phoenix sucks.
#3527
Bikes: Cinelli Vigorelli
Just got some Deda compact drop bars in white and a pair of brake hoods and levers. Is there a 'proper' position for the hoods to be installed on the bar? What about drop bar angle in relation to top tube? Is there a correct angle or is it more of a fit preference?
Really want to wrap these things, but I'm guessing there will be adjustments that bar tape will prevent from happening smoothly.
Tyler
Tyler
#3528
Still kicking.
With a compact drop bar, where you hold the drops should be level with the top of the bend of the bar.
Appreciate the old bikes more than the new.
#3530
Cat Enthusiast
Bikes: All City Nature Boy
Scrod,
What is your intended purpose the the BK you just built? It looks awesome, seriously tasteful and nice build(unsurprisingly), but I recall you mentioning you used your Kagero for distance and the 722 for bombing around town, so I was just curious what gap you were filling with the BK, or if you just wanted another sexy option.
#3531
Cat Enthusiast
https://www.ebay.com/itm/LEADER-S805-...8#ht_777wt_922
#3532
Wear One
between a kilo tt and a 722ts, which of the two would seem like a better ride for daily commuting as well as metric century rides?
#3533
The 722's geo is a little more forgiving but considering that both of those frames don't have provisions for water bottles or clearance for fenders (which you may need commuting), I would choose something else if that's your overall plan for the bike.
#3534
Just came across this on eBay, figured I'd post it here.
#3535
Scrod,
Not sure if this goes in the retro-gression thread or here, but I'm going to put it here because I've already purchased the item and I just need some technical help. I just purchased a stem and these bars: https://www.retro-gression.com/produc...drop-handlebar I didn't realize the tops were as flat as they are. Where am I supposed to mount the brake lever / what size lever do I need? I usually use a cross lever on the right hand side of the bars, so should I just go with a 31.8 and mount it just right of where the stem clamps to bars? I really only use the brake for emergencies, but my only issue is that I feel it will be too close to the center and I will have to re-position my hands from the edges to the center pretty quickly if I need to stop. Thanks for any help you can give me!
#3536
You need to use a lever with a 31.8 clamp, as seen here:
That's typically where any cross lever should be mounted on drops (flat or otherwise), unless you want to lose half of the top hand position.
#3537
Scrod,
Seriously though, I've always liked EAI frames and like to ride what we sell. I can't really have a solid opinion on something unless I have some experience with it.
I just wanted to build a bike that would be good all around. I think I've finally done it with the Bare Knuckle, as it seems to be what I may have been looking for all along. I love all my bikes but I think the BK is my favorite (and not just because it's new).
#3538
Awesome; thanks for all the help scrod!
#3539
Wear One
comparable to all the bikes you own, is the Kagero worth the $$$?
#3542
What length post do you have? The shorter ones (250mm) have logos that are closer to the top.
When do we get to see your whip?
#3543
Brown Bear, Sqrl Hunter
Scrod,
How do we make Calv finish his bike before the world ends this year?
#3544
Cat Enthusiast
x2, let's see it!
#3545
Painfully average.
I'm already riding around in Davis
Now I feel even shorter because I have the shortest seat post
#3546
i smell bacon
Bikes: Geekhouse Deerfield, GT Edge Ti, Spooky Skeletor, TET Track, Ritchey P-650b, Bridgestone MB-3
Do you know the recommended spoke tension for A23's?
Also, is it normal for the Lasers to wind up as I'm tightening them?
Also, I forgot to lube the nipples before putting them in the spoke holes (I lubed the threads though). Should be ok?
I'm learnin'.
I'm learnin'.
#3550
Cat Enthusiast
calv, Kagero looks good!
How did you(or Angie) finish off the bar tape without finishing/electrical tape?
