raleigh
Old 11-28-04 | 04:09 PM
giant99's Avatar
raleigh
Can you put a sealed bottom bracket in a raleigh not sure of the year of the frame ser# RB907364 Thanks
giant99 is offline
Reply
Old 11-28-04 | 04:44 PM
moxfyre's Avatar
cyclist/gearhead/cycli...
Bikes: Homebuilt tourer/commuter, modified-beyond-recognition 1990 Trek 1100, reasonably stock 2002-ish Gary Fisher Hoo Koo E Koo
Well, Raleigh BBs are English threaded so no problem there! You should be able to put a sealed bottom bracket in provided that the right size BB is available. Standard diameters are 68 and 73 mm, and various lengths are available. Measure it, then try the Shimano UN-73 for starters: https://www.performancebike.com/shop/...tegory_ID=5140
moxfyre is offline
Reply
Old 11-28-04 | 04:53 PM
capital D
20 Anniversary
Hi giant99
It all depends on what year the frame was made because Raleigh had their own thread pitch in the early years check Sheldons page for more info https://www.sheldonbrown.com/raleigh26.html
Sorry i cannot be more specific but hope this helps a little
Leigh
Leigh is offline
Reply
Old 11-28-04 | 04:56 PM
giant99's Avatar
Had a look, at the $ 50.00 price range would I get a good quality bb.
giant99 is offline
Reply
Old 11-28-04 | 05:31 PM
moxfyre's Avatar
$50!? Yeah, definitely! I've never paid more than $30 for a square-taper BB (I know
some of the fancier cranksets use more expensive BBs).
The Shimano UN-72/73 BBs have worked fine for me. I have used them on at least 3 bikes and haven't had any problems.
moxfyre is offline
Reply
Old 11-28-04 | 05:35 PM
moxfyre's Avatar
Leigh has a good point. I looked at Sheldon's page and it says that if your Raleigh bike has cottered cranks (the crankarms have what looks like a nail or screw sticking through the base), then it has a different thread pitch and is INCOMPATIBLE WITH MODERN BOTTOM BRACKETS.
Originally Posted by Leigh
Hi giant99
Leigh
moxfyre is offline
Reply
Old 11-28-04 | 06:27 PM
giant99's Avatar
Think Im good to go everythimg that was on it is Exage Motion. Except the brakes there shamano. No cotter pin.
giant99 is offline
Reply
Old 11-28-04 | 07:38 PM
moxfyre's Avatar
Well in that case your bike is WAY newer than everyone thought Probably 80s...
moxfyre is offline
Reply
Old 11-30-04 | 03:53 AM
Bikes: Rudge Sports, Robin Hood 3 speed, Hercules touring, a fleet of big black lugged city bikes
Phil wood sells adaptor rings that allow use of cartridge BBs in Raleigh 26 tpi threaded BBs.
Rudgey is offline
Reply
Old 12-05-04 | 07:01 AM
giant99's Avatar
Ive been trying to get a fix on the year of this bike but have come up dry. Ive had a look at every Raleigh from 80 to 89 but have not found a frame that looks like it. The top of the forks are rounded and at the back its a single post coming down not two with a piece welded in for the back brake. Kinda like a mtn bikes back end. The only one Ive found that looks like it is the 2004 team racing frame but its carbon fiber. It has the steel badge on it that just says "The Raleigh" Before I sanded it to bare metal it was black metal flake. Its decals were rough and hard to read. the bars that were on it are modolo flash, watomic design, made in Italy. probably the lightest Ive ever held.The seat post is SR laprade. Found out the shamano makes the exage motion cranks but not the year they started making them. Well here I am any ideas. thanks 99
giant99 is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
