Clips which clip into clipless
Old 11-29-04 | 12:57 AM
archer_root's Avatar
Carfree Freight Commuter
Bikes: Bianchi
I am trying to find a source for the clip platforms that clip into clipless pedals.
Just in case this sounds a bit obscure, I am looking for these things that snap into a SPD-style clipless pedal and then permit a rider to wear regular shoes (i.e. no cleats) but still have the advantage of the over-the-toe clip.
Anyone know of a source for these puppies.
https://www.ritcheylogic.com/
https://www.crankbrothers.com/
archer_root is offline
Reply
Old 11-29-04 | 01:09 AM
caloso's Avatar
20 Anniversary
Try a tri store. If you do a google for stores and websites that specialize in triathlon gear, you might have some luck.
caloso is offline
Reply
Old 11-29-04 | 01:18 AM
Raiyn's Avatar
I drink your MILKSHAKE
20 Anniversary
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Originally Posted by archer_root
[I am trying to find a source for the clip platforms that clip into clipless pedals.
A
HTML Code:
<a href="https://www.ritcheylogic.com/">Ritchey</a>
and
HTML Code:
<a href="https://www.crankbrothers.com/">Crank Brothers</a>
fan.[/FONT]
That's a terrible font.
<mod's comment> You're right. I had trouble reading it so I edited the post. </mod's comment>
Raiyn is offline
Reply
Old 11-29-04 | 02:22 AM
catatonic's Avatar
Chairman of the Bored
20 Anniversary
Bikes: 2004 Raleigh Talus, 2001 Motobecane Vent Noir (Custom build for heavy riders)
I assume you mean toe-clip adaptors?
a little bit of goo, a little bit of gle, and BAM!
https://www.performancebike.com/shop/...tegory_ID=5245
catatonic is offline
Reply
Old 11-29-04 | 04:47 AM
khuon's Avatar
DEADBEEF
20 Anniversary
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
BTW, I've used those adapters and they're ok but they flex a lot and offer nowhere near the stability of real metal toe-clip pedals. However, if you just want to use them for tooling around town in sneakers then they work fine. Just don't expect them to be comfortable for any kind of performance cycling. You might also want to check out the Winwood Decksters if you're not interested in the clips and straps and just want a platform. These are actually made of metal and feel much more stable.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
khuon is offline
Reply
Old 11-29-04 | 06:17 AM
dobber's Avatar
Perineal Pressurized
20 Anniversary
Get a pair of Crank Bros Mallet C's.
dobber is offline
Reply
Old 11-29-04 | 06:20 AM
slvoid's Avatar
2-Cyl, 1/2 HP @ 90 RPM
20 Anniversary
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
You mean like these:
No need for an adapter, it's SPD on one side, and platform that's cage-compatible on the other.
slvoid is offline
Reply
Old 12-01-04 | 04:53 PM
Bikes: Bianchi
Are those Shimanos? I think I've seen them at one of my favorite local shops. I see what ya mean. I could fix toe clips onto those pedals. But then when using clipless, I'd be scraping the clips whenever I lean low through a turn. Hmmm. Thanks for the suggestion!
I like these Winwood Instep Pedal Inserts for Shimano SPD (thanks to catatonic!). They've got clips on them and can be removed after any use.
https://www.mtbr.com/reviews/Pedal/product_68620.shtml
Reply
Old 12-01-04 | 06:42 PM
gcasillo's Avatar
Maglia Ciclamino
20 Anniversary
Bikes: Bianchi Aria, Bianchi Volpe
I've used Winwood Insteps. Pretty nice.
gcasillo is offline
Reply
Old 12-01-04 | 08:40 PM
DanO220's Avatar
SoCal Commuter
20 Anniversary
Bikes: Surly Crosscheck single/9 speed convertible, Novara Buzz beater
I just keep an inexpensive pair of plastic platform pedals around.
They spin on almost as fast as anything that would clip in and
probably do a superior job. They'll also take old fashioned clips
and straps. DanO
DanO220 is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
