Classic Error : Stripped Left Hand Threads
I have had the Giant Boulder for eight years. The hard plastic, covering the pedals was splitting. I picked up a new set of pedals and began to take off the old. The fact that the left pedal used left hand threads completely went out of my 70 year old mind. Commonly called a "senior moment". Using a force arm on the wrench, I turned the bolt on the pedal the wrong way, thus stripping the treads in the alumium crank arm. I am going to get the pedal unscrewed and try to epoxy the new pedal in place, as the damage is already done. Or : Suggestions?
Best,
Steven in DeLand
Best,
Steven in DeLand
Quoted: 1438 Post(s)
Liked 1,092 Times
Steven: The crank arm can be drilled out and tapped for a threaded insert called a Helicoil, which will restore your threads. Check with your local bike shops or less likely, a machine shop. You will need to end up with a 9/16x20 left-hand thread. You could also buy a replacement left crank arm. I wouldn't recommend epoxying the new pedal into the stripped crank.
Whatever approach you take, be sure to grease the threads of the new pedals before you mount them to prevent seizing of the dissimilar metals. I recommend Tef-Gel. Stainless steel pedal washers may also help get them loose when the time comes.
Use a proper pedal wrench when you mount the new pedals and torque them well, loose pedals are the leading cause of stripped crank threads. It sounds as if you were able to exert plenty of force with the tool you used, though.
Quoted: 114 Post(s)
Liked 119 Times
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Buy a new (or used) crank arm and be done with it.
Epoxy is not something I would use where my life is at stake.
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
Best,
Steven in DeLand
Best,
Steven in DeLand
Did you get the pedal all the way on cross-threaded, or only a few threads? If the latter, simply get hold of a left-handed pedal tap or pay your LBS to run the tap through starting from the good threads on the inside.
Don in Austin
Super Moderator
Liked 927 Times
I think the pedal was already on, and he kept tightening it (instead of loosening) with such force that the threads stripped out. Thus, I would assume there's not much left in there.
Quoted: 5774 Post(s)
Liked 2,571 Times
It takes a staggering amount of torque to strip a 9/16" thread by overtightening. I'm curious to know how long a cheater bar the OP used, and if it was less than 2 feet, I'd like to see a photo of his biceps.
FB
Chain-L site
FB
Chain-L site
Thanks for all the tips.
In order to screw this job up, I had removed the crank arm from the bike and wrapped it with leather, than snugged it into my bench vise. A 19/32" open end wrench fit the flats on the pedal very well. Since I could not strip the aluminum thread with just the force that I could exert using the 8 1/4" long wrench, I got the steel tube used to lock down the leveler bars on my travel trailer. The tube is 18" long, with a 7/8", inside diameter. That gave me a 26" long force arm, when I slipped the tube over the jaw of the wrench and hung on it. The first turn was difficult, than as I now know, when the aluminum threads failed, the job got easier. By time I realized my error the threads were toast and were not coming out of the crank arm at all.
I phoned the local bike shop and they are working on finding me a crank arm, or getting the a bushing to fit into the reamed out hole.
Thanks again guys,
Steven
Thanks again guys,
Steven
All I can say is that I hope when I am 70, I'll still be riding and maintaining my bike(s), and strong enough to strip a crankarm by over-tightening a pedal. My hat's off to you, sir! Color me impressed.
Roy, that method works but probably is faster just go and buy a new crank or crankset as somebody mentioned before. Depends of the way u want to go, besides cranks aren't that expensive if u get a used one, maybe even free.
Yeah, I hear ya. Going to phone the shops as soon as they open up. I went to two shops in DeLand, FL., yesterday. Both were closed up. Gone! Sad commentary on the world economy today!
Tastewar : Thanks for the kind words! My only answer is to say first, all credit goes to God for giving me a body that, if I try, can keep going. Secondly, as a steward of this body, I must keep up exercise. I bicycle 10 to 20 miles a day. Granted, I am in FL. with no hills to speak of. I lived most of my life in Maryland, where I bought the Giant, Boulder bike. The trails around the reservoir were brutal and today, I could not do it. I tell anyone who ask, that the secret to keeping fit is to "give" to yourself at least one hour per day and keep up that one hour or more exercise. And I mean sweat creating exercise. My dentist said that she does not have time to do that. She is in her late 40s. So, I ask her how much time she spends generating cash in her practice and she said 40 hrs./week. I then ask her if she could get up one hour earlier, or go to bed one hour later, because after spending 40 hrs./week generating cash, she really needs to give her body at least 7 hr./week, doing exercises, in order to keep the body going! That is the way one must look at it.
In my 70th year, I am no where near ready to sit in front of the TV and wait for the grim reaper! God willing, I will keep on biking for another 20 years.
Best,
Steven
Best,
Steven
Super Moderator
Liked 927 Times
Best,
Steven
Best,
Steven
You can find left crank arms on Ebay for little money. If you want an exact match, it may be more difficult. Make sure you match the length (170mm, 172.5mm etc...) and type (square taper, octalink etc...)
