How do you define a hilly ride?
Bikes: 2015 Specialized Diverge Comp Carbon, 2011 Cervelo R3, 2011 Trek 2.1, 2011 Trek X-Caliber
A friend was up visiting from FL last weekend and he brought along his bike. He wanted to do a couple of rides in the 25-35 mile range, preferably one flatish and the other moderately hilly. This got me thinking about how we define the hilliness of rides. I know ascents are categorized from HC to cat 5 but I didn't know if there were any broad classifications for total rides?
So I looked back over a year's worth of Garmin data trying to find rides that would fit his needs. This turned out to be a useful exercise and I ended up categorizing my rides by their hilliness factor
This is the formula I came up with for rides in the 25-60 mile range along with my avg moving speed for each class.
Flat rides: Less than 300 ft elevation gain per 10 miles: 20+ mph avg
Flat to Rolling: 300 to 500 ft gain/10 miles: 18-20mph avg
Rolling to moderately hilly: 500 to 700 ft gain/10 miles: 17 to 18 mph avg
Moderately hilly to Hilly: 700 to 1000 ft gain/10 miles: 15 to 17 mph avg
Hilly to Very Hilly: 1000 to 1500 ft gain/10 miles: 12 to 15 mph avg
In the end we did one ride that was at the high end of the flat to rolling class and another that was in the low end of the mod hilly to hilly class. Coming from FL, he felt the first ride was 'a bit hilly' and the second ride 'downright hilly'
How would these classifications compare to rides in your area?
Shredding Grandma!
Bikes: I don't own any bikes
Quoted: 46 Post(s)
I do a ride that's 3500' ft of climbing in 15 miles... I consider it rolly to hilly (since its alot of up and down and up and down). I've learned over the years that "hilly" is relative. What is a "hill" to me might now be a hill to someone else or vice versa. I was planning this route and a friend said... "do we have to do all those hills!!!" I responded "Hills? It's a flat ride.... oh you mean the overpasses!!!".
A hill to me means there is at least a mile of climbing at a grade of 3% or more. Hilly means there is a lot of that or more. Where I live it's a fairly hilly place; it's hard to find a long flat ride (along the beach is about it and even then at times it gets "rolly"). But it depends on your fitness level, skill and experience. I don't think there's a formula and actual definition. It's not fair to tell beginners that 4 mile grade at 2% is not a hill. at some point that "mountain" becomes a molehill and the rider finds other challenges.
______________________________________________________________
Private docent led mountain bike rides through Limestone Canyon. Go to letsgooutside.org and register today! Also available: hikes, equestrian rides and family events as well as trail maintenance and science study.
Bikes: Trek Navigator, LeMond Buenos Aires, Madone 5.9, S-Works Roubaix
but the steady climbing combined with the altitude whipped me pretty good. Of course when we got to go down for 20 miles that was lot's of fun
It all depends what you're used to. It isn't especially flat round here, and the ride I most frequently do when I have 2-3 hours to spare is about 40 miles with roughly 2000ft of climbing. That's what, about 500 ft per ten miles? I'd call that moderately hilly.
Bikes: 1989 Panasonic DX2000
I call what I ride moderately rolling terrain usually no more than 1000 ft of gain and I can average 15-17mph on it. Central Carolina area.
Quoted: 2604 Post(s)
Liked 1,929 Times
Hilly depends on what flat is.
I don't think it's possible to come up with an overall definition - maybe because I live in rolling terrain. I tend to define rides by the biggest climb. For instance, last weekend's ride probably had over 2,000' of climbing, but only three climbs; one was about 0.5 mile, the second 1.5 (at about 8%), and the third 0.25 mile (at about 10-12%). There were a bunch of fun rollers getting to the bottom of the second climb; I was able to attack those from the previous downhills, and rarely had to shift out of my big ring. But the total of those rollers was likely more than the 1.5 mile grind that came afterward.
Maybe "hilly" should be defined as the fraction of a total ride you spend in low gears?
Bikes: Bridgestone RB-1, 600, T700, MB-6 w/ Dirt Drops, MB-Zip, Bianchi Limited, Nashbar Hounder
I've never really stopped to classify a ride by elevation gain so much as the probability that the ride would force me to get off the bike and walk it. I've discovered that for many riders, there can be lots of hills and lots of variation in elevation, but the one that kills me and makes me suffer so badly I have to get off and push or makes we wish I went home, is the one that defines the "hilly" ones.
Bikes: 2012 Surly LHT, 1995 GT Outpost Trail
Yikes. And here I thought 1000 feet per 50 miles was considered "hilly".
Guess I have a lot of weight to lose
I apparently have yet to do any "real" hilly rides.
Good question. In your shorter rides, I generally do my 10% rule: If it has 1,000 feet of gain or more per 10-miles (I call that 10%, even though it's not), it's a tough ride. And this continues on for whatever mileage.
A year or so ago, I had tried to do something similar for century rides. I haven't really publicized it, so it hasn't caught on. It's a subjective evaluation based on feedback from other riders. I looked at several rides around the SoCal/NorCal area and asked some online friends.
The chart looks like this:
Well, you can find hills in Northern MN... Just it is a lot easier to get in a hilly ride when you live on top of a 500 foot tall hill that works out to be around a 15-18% grade... Means there is an easy 500 feet of climbing in even a 1 mile ride. And if the valley is only a mile or two wide, well, then getting in 1000 feet of climbing in a 5 mile ride becomes a piece of cake. It'll also cure you of any illusions of bike heroism you might have had.
These days tho, I live in nice FLAT Madison WI. If I want to get in climbing drill, I have to pick a route with a big hill on purpose. And even then, I have to go hunting to find anything remotely as unpleasant as my childhood rides home from the library. It makes a nice change.
That said... downhills make climbing worth it. I don't care if I have to walk up the hill if that's the price I have to pay for zooming down it. And I am always horrified at discovering hills where you actually need to pedal to get down them. It is perverted and wrong and immoral. You're supposed to need your brakes on hills so you don't break the speed limit! That kind of hill is well worth routing around.
Uber Goober
On my ride log on bikeforums.net, there's a category for "hilly", "rolling hills", etc, and I just leave it blank. If you're just starting or from the flatlands, every little bump is a major obstacle, if you're Mr. Beanz, then you don't notice that little 1000' hump in the middle of the ride. There's spots that I had to downshift and climb over when I first started that i don't even think about being hills now.
2 Fat 2 Furious
Bikes: 2009 Specialized Rockhopper Comp Disc, 2009 Specialized Tricross Sport RIP
I agree it depends what you're used to. Where I live is mostly pretty flat in most directions - there are a few steep hills but nothing hugely long (e.g. one hill is 10% but only for about 400 yards).
When I visit friends in PA who live in a valley I see the descents with warning signs "8% for 3 miles" etc, and see some of the other ridges, and figure that's nothing like I will ever experience around my normal cycling ground.
Bulky Bullet
Bikes: Burley Koosah / RANS Zenetik Pro / Catrike Expedition
In Florida, a speed bump is a "hill." LOL
"Obstacles don't like me very much. I make them look bad."
Ridin' South Cackalacky
Im not motivated enough for all that charting and data collecting and so on. I'm just a guy on a bike.
But, if Im gaggin for air in the lowest gear and the road ahead looms OVER my head, I call that "hilly."
About half of my riding is that type.
The other half is the descents.
I've been agonizing over whether to do this ride this weekend: https://www.mapmyride.com/routes/view/52001136
This is the most hills I've ever done, by far. MMR says 1300ft of climbing, but in my experience they are always off by at least half. I predict it's closer to 2500-3000 feet, over 40 miles. It says 3 category 5 climbs. Which scares me. I've only done 3 cat5's ever so far, each on separate rides. Each one exhausted me to a point where I could hardly continue. I end up doing them in my lowest gear (22/27), at a cadence of about 50, because I simply cannot spin any faster. I drove the course already... these hills look even bigger than the previous cat5's I've done.
Sigh.
Sigh.
If you're alternating between trying to maintain a decent cadence in a low gear while keeping your lungs from exploding followed by spinning out in your highest gear with a big grin on your face, it's hilly.
If you break your tuck to stay under 40mph, it's hilly.
If you pass a jogger, and you worry about staying ahead of him, it's hilly.
