Specialized Camber welding frame issue
Bikes: 2011 Specialized Camber, 2011 Giant Cypress DX, 2008 Hard Rock Sport
.jpg
If you look right below the seat post, there is suppose to be a triangular hole. However it looks like specialized has welded it shut. I just bought this bike a few days ago. Should I contact Specialized or the bike shop I bought it from? Also, what do you think the bike shop or specialized can do for me. Is it worth me going back and getting another one?
Thanks
Thanks
Super Moderator
Quoted: 1173 Post(s)
Liked 924 Times
I don't see the seatpost ... and why do you want a hole in your frame ?
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
Looking at net photos of a camber there is an open triangle on the pictures ... but that may vary on frame size. If you just bought it, check with the LBS you purchased it from first. Look at other frames the same size. I don't see how it would affect anything other than making the bike easier to clean without the "hole".
Mate that's a brace. It's supposed to be welded, and it's structural, you want more material there not less unless you plan on hanging the bike on a wall so you can admire the neat welds and nice little hole between the top tube and the brace.
Ride it!
Ride it!
Hmm... Above the rear shocks would be a better description
Quoted: 453 Post(s)
Liked 104 Times
What size frame do you have, often those holes in the frame will be closed by the time you get to the smallest model in the range.
Bikaholic
Bikes: Trek Fuel 90, Giant OCR, Rans Screamer Tandem
Looks like only one shock to me. Looks like the smaller frame cannot accomodate the hole. You can check with the shop to be sure but the bike is fine without it - probable stronger in that area - don't sweat it.
bike whisperer
Quoted: 1520 Post(s)
Liked 716 Times
What is this 'shock' you speak of?
I see only a gas-sprung damper.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Bikaholic
Colloquial nomenclature is always fun. Specialized says this about it on their site:
Either way, there is one rear air shock/ gas damper.
REAR SHOCK - RockShox Ario RL, air spring, rebound adj. and LO, 200x51mm
Bikaholic
thrasher9905
9
05-13-16 05:35 PM
snafuboy90814
2
11-02-13 10:50 PM
