Can Anyone Recommend A Good Bike Light
Bikes: 2012 Trek 8.3 DS
Can anyone recommend a good LED bike light? Preferably one that charges with a USB. I've found that a lot of them are $150 and up. Kind of pricey for a little lamp.
What will be the purpose of the light? As a true headlight for night riding, or more as a "be seen" light? There are a lot of options out there for both, but it would help to know what kind of riding you have in mind.
Bikes: old Huffy, Newer Mongoose
for years I have ridden with the old style generator light sets. I just ordered 2 for my current bikes, from Amazon. I hate batterys, and I have been so screwed by garbage light sets off ebay. back to the old generator style for me!
Both. I would like to have the option of going out at night and riding some of the paved and non-paved trails around where I live, but at the same time I want to ensure that I don't become road kill.
I just bought one of the 2W Blaze lights from Planet Bike last week. It was $55 at REI minus the 20% discount they've got going through Sunday. It has low, high and blink settings and the latter two are absolutely blinding.
Battery life is a bit of an issue though, I may need to invest in rechargeable batteries. I also hate having to take it on and off every time I stop and lock up my bike but there is no way I'm leaving 50 bucks sitting on my handle bars. I didn't care before, when it was just a cheap Cateye.
Bikes: 2009 Giant Cypress DX 2009 Jamis Coda Comp
CygoLite ExpiliOn or MiliOn. The CygoLite ExpiliOn 350 is bright, the charge last a good while and charges on USB. $110
Why do you want it to be charged with USB specifically?
There is little to be gained from charging something with USB ... in fact there is only maximum amperage to be lost.
Two-Wheeled Aficionado
Bikes: Santa Cruz Blur TR, Cannondale Quick CX dropbar conversion & others
Liked 5 Times
How much runtime do you want? I'm using some single 18650 LED flashlights (Ultrafire WF-502b) and they are super bright with a great pattern, but they have less than 90 minutes of life. Fine for my morning fitness ride, terrible for serious nighttime use.
You need systems with external batteries if you want bright and 2+ hours of life.
I would give up the USB charging requirement. That will limit you to either really small lights, or really long charge times.
BTW: there's a lights & gadgets forum here on BF. Very good tips and specific product recommendations there.
Liked 5 Times
A 18650 is a 3.6/3.7 volt lithium ion battery about 50% thicker than a AA and twice as long. They range from 2000 to 3000 mAh. Strong flashlights nuke a single 18650 in under 90 min like I said earlier. Magicshine and numerous other systems might use a battery pack with anywhere from 2 to 6 18650 cells in them. (There are several other lithium options too.)
My cheap-o charger gets them fully juiced in 2.5 hours.
I started commuting before dawn and quickly found that i needed more than my little $30.00 Planet Bike light and did some research and found the most bang for the buck with Jet Lites. I got the A-51 model and it is bright enough for real night rides. I forget the actual lumens, but it was way brighter for the money than the other high end lights. The battery is light weight and charges quickly with a plug in the wall charger and lasts a long time... several hours. $230.00 Check em out on line.
If you do go with batteries, Sanyo's Eneloop rechargeable batteries work. I've been using them for years in all kinds of things -- bike lights, cameras, Wii remotes, etc., and they perform in all of it. Not at all like rechargeables of old.
Bikes: Specialize
the HL-EL135 cat eye lights seem to be pretty bright and not to expensive. I think if i remember correctly that light is like $20. Oh and it doesn't seem to use a lot of energy from the battery.
agmetal
15
11-26-16 10:03 PM
PaulRivers
Commuting
22
06-14-11 12:30 PM
PaulRivers
12
06-04-10 01:20 PM
