Handlebar height...
Liked 7 Times
Handlebar height...
How much difference does the height make? I find myself leaning forward a bit more than I like, but this is the way I bought the bike. The guys at the LBS said that I could adjust them. What difference would adjusting them up mean to me?
Looking at the picture on your blog, it looks like your bar height is a bit over saddle height. Raising bars further will take weight off hands and place it on your rear. This isn't necessarily a good thing. I'd suggest a good pair of gloves if you don't already have them and give yourself time to get into better shape unless it is causing serious issues.
When I returned to cycling a few years ago after a 30 year hiatus, I felt the same thing, too much weight on hands. But the more I rode and the more I got in condition, the less of an issue it was. Now, even my vintage MTB has a significant saddle to bar drop.
Quoted: 18883 Post(s)
Liked 10,646 Times
If you're learning forward too much, it sounds like a fit issue, although it might also be to do with core strength. I saw a pic of you with the bike on your blog, but not of you on the bike. One of those would help, or you might be able to get the opinion of someone at the shop?
Moving the bars around can make lots of different kinds of difference. It changes your posture, and, if you care, your aerodynamics. Lower bars are faster, but it doesn't look like you're trying to race.
You can move the bars up or down by changing the stem, or by adding and removing spacers. It's a five minute job, and probably won't cost more than about $40 - that's if you bought an adjustable stem. I'm not a fan of these, because they aren't very stiff and make me nervous when I stand on the pedals to climb a steep hill. But a lot of people (including yours truly) use an adjustable stem to figure out where the bars should be, then get a normal stem once they figure that out.
In case you haven't encountered them yet, this is what I mean by "adjustable stem:"
I think it depends on a number of things. I used to be thin, and had no problem with bars significantly lower than my seat. I'm not thin now, not by a long shot, and find that low bars make it tough to breathe. Raising my bars a couple of inches, and bringing them closer to me, has already made a big difference in stamina, hill-climbing ability, how winded I feel. So, for me, raising them was definitely a good thing.
If you ride in town a lot, higher bars make it easier to see what's going on, and to see who'd behind you - like when you need to get over to the left to make a turn. If you ride long distances, lower bars, and having the weight more evenly distributed among the seat and the hands is probably better.
Liked 7 Times
Well, I think my bars are adjustable anyway. At least that is what the guy at the LBS told me that I just needed to loosen the Hex nut and I could pull them towards me and also upward. He said that they are at their lowest as they are, both ways.
Liked 10,646 Times
Well, then it's a 2 minute fix, and for no money. Can you post a photo of the stem?
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
I like my bars lower than my saddle, a couple of years ago the bars were higher than the saddle, but as I ride more, the bars dropped and the saddle went up.
Liked 7 Times
Found a pic of my bike on the trek site - https://www.trekbikes.com/us/en/bikes...on/hybrid/7000
Liked 10,646 Times
Looks like an adjustable stem to me. Loosen the screw in the middle of the joint, pull the bars upward, then tighten it back down. You'll probably have to loosen the front of the stem after that, and rotate your bars back to the way you like them. It's very, very easy.
Liked 7 Times
Now another question...will the bars being more upright, will that change the feel of the ride? Make it harder, easier? Me being more upright should make some sort of difference, right?
It will make a difference but doubt it will be dramatic as you haven't been riding long and are probably still getting acclimated to being in the saddle. But, as it is a $0 change, go for it and see if it is better. You can always go back if you don't like it.
Like I said, experiment and you'll find out. Obviously if you are more upright your air resistance will increase, but if you're more comfortable you may be able to put out more effort. The only way to know, is to try it.
Liked 10,646 Times
Being more upright means you'll present more frontal area to the wind. Going 20+ mph will be a bit harder; 15 mph should be imperceptibly different. If it makes you more comfortable, it's a good trade off. It's not like you're on a time trial bike competing in races.
Measure the distance from your handlebars to the ground with the bike upright, and the distance from the nose of the saddle to the bars, before you change anything. Write these down. If you don't like the change, you'll be able to put things back exactly.
"Florida Man"
Quoted: 1571 Post(s)
Liked 1,707 Times
Allen, the tilt of the saddle can also affect the pressure on your hands. If you tilt the saddle so the nose is a bit higher, it will take some of the weight off your hands. I couldn't tell how you're set up now from the photo.
An extra hand position can be helpful, too. You can add bar ends for a cheap and easy fix. Then, you have to remember to change positions rather frequently, and that can help.
As others said, weight loss and core strength make it easier on the hands in the long run. Good luck.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
Not so good for the racer boys since you become a brick to shove though the air.
Ain't nobody gonna convince me that riding folded in half on drops is comfortable. No sir.....nobody !!
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Bike ≠ Car ≠ Ped.
A higher handlebar height for me is harder on my back, believe it or not. If I've got some amount of forward lean, bumps from the road make my torso "rock" in place; if I'm sitting bolt-upright, bumps shoot straight up my spine. If I were to ride a bike like my wife's Electra Townie very often, I'd spend a lot of effort choosing a saddle and/or seatpost to reduce those shocks. I'm not ten years old anymore.
Bikes: Specialized Secteur, mostly ultegra triple
It seems very counter-intuitive, as everyone seems to say to raise the bars if you have back pain. Guess that's what took me so long to figure it out.
Liked 10,646 Times
ghostofcrujones
General Cycling Discussion
20
10-08-16 08:45 AM
