simple question about bicycle headsets,
Hey everyone,
.. like the title says, just a simple question:
Whats the most common size for bicycle headsets?
(in diameter, like 1 1/8 inch)
.. and for that most used size, what are the corresponding headtube and steer tube diamters?
Thanks for all replies!
cheers,
Fabian
P.S. I hope is post is understandable, my mother language is german
cheers,
Fabian
GONE~
It's hard to say but for most modern road bikes with threadless headsets, they will generally be 1 1/8". With older steel bikes with threaded headsets and quill stems, it would generally be 1".
Quoted: 5766 Post(s)
Liked 2,538 Times
While you're at the SB site, you should bookmark it as a reference source for the future.
FB
Chain-L site
FB
Chain-L site
Liked 2,538 Times
Yes, but the steerer tube diameter at the base where the crown race fits will be 30mm. The crib sheet I linked you to gives you the data you need, subject to rounding errors when converting imperial to metric dimensions.
FB
Chain-L site
FB
Chain-L site
