what the plastic disk for?
Chief Wheelfoot
Bikes: kona jake, dahon boardwalk, Surly LHT
whats that high teh looking plastic disk begind the cassettes purpose? can i take it of without the world collapsing on itself?
I am a lonely visitor
Bikes: Michelle Pfieffer, the Carbon Fiber Wonder Bike: A Kestrel 200 SCI Repainted in glorious mango; Old Paintless, A Litespeed Obed; The Bike With No Name: A Bianchi Eros; RegularBike: A Parkpre Comp Ltd rebuilt as a singlespeed.
The disk is supposed to keep you from shifting your chain into the spokes. If your rear derailleur is properly adjusted, you can remove it without any harm or danger.
All the cool kids remove them.
Religion is a good thing for good people and a bad thing for bad people. --H. Richard Niebuhr
Bikes: 2 many
If you do over shift past the last cog and the chain goes between the cog and the chain it is likely that the chain will damage some of the spokes. if the spokes are cut or notched a little (they will be) you would have to remove the cassette etc. to replace the spokes. It depends on how confident you are about having the derailleur stop screw just right all the time. If the dropout gets bent it can cause the chain to go off too.
Do you know how to check that adjustment if it goes off?
Originally Posted by The Fixer
If you know how to fine tune derailleurs, you have our permission to get rid of that offensive looking disk.
After that, I decided the spoke protector has value and reinstalled it. I'm the only one in my ride group with one, but as long as I'm the first one up the hill, no one laughs at that unsightly disk.
Put your bike on your repair stand (for people that think they can get by without one, here is a perfect example of why you DO need one) so that you have access to the drive side of the bike. Shift the RD into the highest gear (i.e. - the little cog). Now, turn the crank with one hand and, with the other hand, push on the bottom/right of the derailleur parallelogram - this will drive the chain to the low gear (the big cog). Keep cranking. If you let the parallelogram go, the chain will shift back to the high gear (because that's where you have the shifter set).
The adjustment you want to make is the "L" limit screw. You want to set the low (= "L") limit screw so that your RD shifts smoothly to the low gear, but not beyond it. When you push on that RD parallelogram you want to push firmly. If the chain jumps off into the spokes or even starts to grind against them, you need to adjust the limit screw accordingly. Look down into the parallelogram and see what the limit screw does and what it stops against.
No need to shift through any of this. Just keep cranking - push the RD so the chain moves up the cogs - adjust the limit screw so you get to the big cog and not beyond.
While you are at it you might as well adjust the "H" limit as well. When you let the chain come back down to the small cog it should only get to the small cog and not beyond. When you are done with the limit adjustments keep cranking and shift through all the gear combinations and fine tune if necessary.
You can do these adjustments with the shift cable disconnected if you want. Cable tensioning for index shifting and "B" adjustment are another issue.
I just cut mine off recently...because I am a slave to conformity and couldn't bear to be the only guy riding with one.
Seriously though, my D's are adjusted properly and I haven't had an issue yet. Plus, if I do end up destroying my spokes I have an excuse to upgrade my wheelset.
PJ
PJ
PJ
Giggity giggity!
Bikes: Yeti DJ Custom build. X.9, Marzocchi, RaceFace, Gamut, DT, Truvativ, Michelin, Hope.
Originally Posted by sydney
There are a few people in the universe clever enough to do it without one, and have never shifted off the big cog either.
Bikes: 2004 Trek 4600 SS, 2016 Cannondale Cujo 2 SS
I've dropped the chain into "The Void" as I call it, with no damage. It is about being connected to your bike, knowing when a problem might happen before it becomes one. Regular maintainance helps too.
Eschew Obfuscation!
Bikes: 2005 Rocky Mountain ETSX, Surly Crosscheck, 2000 Enduro Expert (sold), 1999 Rockhopper, 1984 Trek 520 (STOLEN-but recovered!), $7 rigid MTB from a police auction (broken, then stolen)
All you have to do is ease up on the pedaling when you shift. Less wear on chain/cogs, no grinding noises, significantly reduced possibility of overshifting damage. I've overshifted a few times but haven't caused any damage because I pedal gently during shifts, and was able to stop the cranks immediately.
Sorry, but also, how does regular maintenance help if the stop screw is set correctly in the first instance?
Just trying to learn something here so I don't repeat my episode...
Originally Posted by DocF
The coolest spoke protector I've ever seen was an old Jerry Lee Lewis 45. Hey, it works and it is different.
Doc
Doc
I like it! Any idea how to attach it to the wheel so it spins with the wheel? I'd like something a bit cooler than duct tape. Perhaps drill a hole thru the record and fabricate a clip of some sort?
Now I gotta hit a vinyl record store.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Elite Rep
I say leave it on. When i'm shifting upwards i usually 'over-shift' to get the chain on the top chainring, i push the leaver further then usuall which moves the derailer past the chain ring so the chain can slide onto it quickly. If i didn't have the plastic disks the chain would slip right past the chain ring and onto the spokes. Like people have said, there is no weight difference and it's just clear plastic so why bother?
edited because someone takes themself way too seriously for their own good
Elite Rep
Originally Posted by Raiyn
Doesn't happen with a properly adjusted derailieur. The "dork disc" correctly identifies you as a novice
