Got a my First CX bike -- question about wheels
Just ordered a motobecane CX from bd. It's at the low end of the component spectrum since it's one of the cheaper one. So I was wondering, would it be a wise move to substitute the stock wheels for an Open Pro (mavic) for the rear and a Velocity (heavy & solid w/dura ace hub) which I use for the front?
In other words can I use road bike wheels with wide (35) CX tires?
Can't tell you all how I am looking forward to riding that thing!
Have bike, will travel
It is common practice to use a 700x32 size tire on a Mavic Open Pro. Using a 700x35 is too wide for the rim, IMO.
Mavic’s website states that 28mm is the widest tire recommended on an Open Pro rim.
If a 700x35 is the right size for your needs, find a wider rim: https://www.ebay.com/itm/Shimano-Tiag...item3a6a86791e or https://www.ebay.com/itm/Bicycle-700x...item415cfae3ea
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
I saw that. But their website also says 103 lbs is the max air pressure for a 32mm tire. Interesting.
I've used 700x35 tires with Open Pros and had zero problems. It seems to me that 103 psi is more pressure than you'd ever want in a 700x32 tire anyway, regardless of the rim. I'm guessing, though, that your main surprise is that they'd even give a maximum pressure for a tire that's outside their recommended size range. If you ask me, that size recommendation is very conservative.
FWIW, my 2008 Kona Jake came stock with 700x35 tires on Alex AT-450 rims, which are several millimeters narrower than Open Pros. That combination has never given me any trouble either.
My Bikes
My Bikes
Alias530
16
12-03-14 11:28 AM
davidm_2004
Commuting
7
10-03-13 05:40 PM
caloso
4
10-02-11 07:52 PM
