Bearing cone. What size and where to buy?
Quoted: 23 Post(s)
I took apart a rear axis of my bike and discovered, that one of the bearing cone has a tiny crack(?) Or it just wore out.(?) Or it was adjusted too tight(?)
Anyway, I would like to replace it.
For instance, Jenson has them, but they all look the same:
https://www.jensonusa.com/store/produ...+Hub+Cone.aspx
But I could not find what is the size/type I do have to order correct part.
My hubs are Formula brand. Bike is Cannondale CAAD 8.
Please, help!
Please, help!
Bikes: ritcheys{2** rm blizzard Geo elrick drop frame and acollection of parts bikes in waiting
Repack, new cone matching profile of old.You can purchase precision balls and sometimes its easier to purchase a axle complete with cones.Carefully inspect the hub races for damage pits etc.Light and a ball point pen to run around the race. Use a plate of glass to check axle for bending.Take it from old cyclist, a crack in the balls is no fun
In the wind
Try wheels manufacturing, your lbs can order what you need.
Quoted: 23 Post(s)
I went to LBS and they gave me new ones - $5 each, they are a little different - few mm longer, but it should not be a problem, right?
The thread on mine is 10x1mm, so I can look up online too. As I understand there is no specification for the ball size. If the thread is 10x1mm it should fit to the the bearing balls used, is it correct?
Quoted: 23 Post(s)
