Review: New Bike Maps App for iPhone
Bikes: Lots
I wrote a review for a new Bike Maps App for the iPhone right after it came out. These were some of my first initial thoughts.
To read the full article with Photos check it out on my blog HERE.
A new app has been released recently to help with navigation on your bike if you own an iPhone. Bike Maps – Bicycle Directions for Commuting and Touring by Burning Robot is the new app offering turn by turn directions for bikes.
This is a review for Bike Maps Version 1.o.1 (12-13-11), I will try and do updated reviews if and when the newer versions are available.
Features
• Turn by turn directions
• Search by keyword or address
• Get bike directions from your current location
• Prioritizes bike paths and lanes
• Avoids busy streets
I downloaded this app for $1.99 to try it out myself. The app uses the power of Google Map’s Bike Route feature. Over all this app is very clean, and works fast over 3G cell service, but might be lacking some features some people might like. Some of what it is lacking is due to some flaws with Google’s Bike Routing, some are things the app developers might have not decided to add in.
The app is quick to access. Runs well pulling up maps over the 3G. When you open it up it takes you straight into the map, with a Search/Address bar at the top. Pretty bare bones which can bee good. You simply type in what you want in the search bar. Say “bike shop” it will give you the shops in your location, just like Google would. You click the pin on the map then it brings up information about that location, and you can just click the “Bike Directions” button on the page. From your current location only, you will be given a single suggested bike route to that location (the best bike route, according to Google, including distance, and time it will take). The route is highlighted on the map and the written directions are shown one at a time at the top of the screen, allowing you to see the map and directions at the same time. You then can click through arrows at the top right to use the turn by turn directions, which give you the distance and where to turn each step of the way.
Bike Maps App - First Screen Bike Maps App - Zoomed In Bike Maps App - Bike Shop Bike Maps App - Bike Shop Selecte Bike Maps App - Info Bike Maps App - Bike Shop Distance and Time Bike Maps App - LBS 2 of 10 Bike Maps App - LBS 4 of 10 Bike Maps App - LBS End
Here are some things the app is lacking in comparison to the full desktop version of Google’s Bike Route feature. It doesn’t show highlighted bike routes, instead it just shows the standard map view. It would be nice if it showed the highlighted map view, then you could use it to plan your own routes. The app also doesn’t suggest multiple routes to choose from, it uses the very first route that would come up if you used the full desktop version. This can be bothersome because in many situations the first choice Google suggests is not the best one. Also there is no way to edit routes yourself. And the app only allows you to get directions from your current location. For the most part this will be fine, but it would be nice to be able to plan out routes from other locations.
I like this app even with what it might lack right now, it’s a good, straight-forward bicycle routing app and it lets you use Google’s Bike Routing feature on your iPhone. So if that is what you want, this will work for you. Also, there are no ads, which is always good.
Features
Bikes: Lots
Yes and NO, It can be used when using add-ons like the Wahoo, but it wont interact with an app lie that Wahoo. It is a basically Google Maps - Bike Routes for the iPhone. It does nothing to record your miles or speed. You would be able to use both apps at the same time.
It work really well, and just the other day they updated. It now has the Highlighted bike friendly streets/lanes/path. and allows you to bookmark addresses. It updates your location along the route as you go, and turn by turn directions(click though, no voice telling you)
utefan001
Road Cycling
0
09-22-10 01:18 PM
