Dynamo hub + USB charger + battery lights charged by USB?
Bikes: Specialized Secteur, mostly ultegra triple
Would this setup work? A Shimano/SON/etc dynamo hub, along with something like the Tout Terrain the plug / pedalpower super-i-cable, charging a "normal" battery light that charges via USB.
The thought is to keep the flexibility of being able to move the light between bikes without a dynamo hub.
Bikes: Surly Long Haul Trucker, Salsa Mukluk, Riese & Muller Supercharger GT Rohloff (Forthcoming)
Quoted: 98 Post(s)
Liked 24 Times
I pretty much have that setup in the sense that I have the SON 28 Dynamo and the PedalPower+ Super-i-Cable but I charge devices such as my phone and my Garmin Edge 800 not "normal" battery light. I suspect with the light you need to check the required input. Can you for example charge it via your computer? If yes, then I suspect that the PedalPower+ SUper-i-Cable will handle it as well.
The output for the PedalPower+ Super-i-Cable is given as 5v up to 1000mA. I will scan the owner's manual and link to it from the review link above. Might help answer your questions.
Regards
Andrew
Regards
Andrew
Tandem Tom
29
11-13-17 08:24 AM
3speed
29
05-17-14 11:37 PM
