Shift grip MAX
Bikes: schwinn
Shift grip MAX
How do I adjust the shift from #2 to #3 (middle sprocket to large one) if the shifting is very difficult and the handle requires a lot of force to turn?
I have tried to adjust the barrel in front of the cable housing underneath the grip shift.
sound like the tension on the derailer 's cable is to tight , reset the shifter to 1 , disconnect the cable from the derailer , this time when you reconnect it , keep the cable a little loser that it was before .also reset the adjustment barrel back in .
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
There is also a common mistake when installing cables on front derailleurs that makes the cable very hard to move. There is a little 'tab' near the pinch bolt/nut on front derailleurs, and the cable is supposed to go over, not under that tab. If the cable goes under the tab it makes the cable very difficult to pull.
Bikes: schwinn
Shift Grip MAX
It was indeed the position of the cable under the tab at the front derailleur that was causing the problem.Once I moved the cable OVER the tab everything worked great, Thanks to the reply #2 for great insignt into the problem.
Bikes: schwinn
Shift Grip MAX
It was indeed the position of the cable under the tab at the front derailleur that was causing the problem.Once I moved the cable OVER the tab everything worked great, Thanks to the reply #3 for helping me with the solution.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
I've done that, too. And then, several years after I learned about routing the cable correctly...................I did it again.
christofoo
Bicycle Mechanics
3
06-10-12 09:25 PM
