Butt rash with padded shorts-What's good prevention?
Bikes: Surley LHT
I am 62 and new to biking.I bought a Surley LHT last summer.I have riden it about 500 miles-mostly in the last 2 months.I plan to do some loaded touring mid March.Last week I took a 2 day ride to try out equipment.I rode 50 miles to a camping area the first day.My right cheek felt a little tender after taking a shower.But I thought nothing about it.I did apply some Chamois Buttr before going to sleep.
The second day I rode 78 miles.Further than I wanted to go.But there were no camping areas or stores in between.Well,mid day my butt was expressing unhappiness.That night after showering,it looked like I had set on a hot iron.Today,5 days later,I finally took a 15 mile ride.My problem was not completely healed up.But I think I could take another 15 mile ride tomorrow and be okay.
Now,knowing this can be a show stopper,I want to know what caused it and how can I prevent it.I have a Brooks B17 saddle.And I wear Izumi padded shorts.I also had thin poly running shorts on.This is what I typically wear.My question is,are the padded shorts holding the moisture against my skin and causing the rash?I thought the padding was supposed to pull the moisture away from the skin.But,I do sweat more than most people.
I read some threads that say more riding time is needed as prevention.But if the cause is moisture,I don't see how more butt hours will help.When on long rides on motorcycles and quads,I wear unpadded spandex.That works great.I will probably try them on my next long bike ride.If there is any advice out there,I would prefer it over trial and error learning by the seat of my er pants.
Thanks
Thanks
Ditch the running shorts. Nothing goes under the bike shorts.
Apply the chamois cream before the ride, not after.
And find a saddle that works for you. Brooks saddles are a cult object but that doesn't mean they fit your butt.
Bikes: Surley LHT
Do you mean,don't wear running shorts "over" the riding shorts?
I had never used the cream before.Never needed it.I put it on afterwards hoping it had some relief properties.
I don't think the saddle itself is a problem for me.It is comfortable.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
Yes ... where are you wearing these running shorts? Under or over?
If under ... OUCH!!
If over ... they could be holding the moisture in and causing problems. I've noticed that if I wear a double layer (shorts with tights over, or something like that), it is less comfortable than just shorts.
Is the problem a rash, or deeper soreness?
If under ... OUCH!!
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Also, get something to cure on going problem. Diaper rash ointment would be good. Apply them before going to sleep, etc.
Bikes: Surley LHT
If under ... OUCH!!
If under ... OUCH!!
My sit bones are fine.The rash? was very red with a slight ooze to it.In the morning it seemed to be more like a thin scab.Triangular shaped and the size of my seat contact area.
Bikes: 2013 Raleigh Clubman, 2010 Schwinn LeTour, 2012 Raleigh Sojourn, 2011 Schwinn Voyaguer 7
I have learned to put chamois creme (cocoa butter) directly on the chamois. I apply a liberal amount to the shorts and rub the creme into the chamois.
On a 65mile ride I had a similar saddle sore as the OP even though I wore Pearl Izumi shorts. Thereafter, I learned about applying the creme directly to the chamois and even on a 100mile ride I did not have any sores or blisters.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
There's a great scene in the Hell on Wheels documentary of a soigneur applying massive amounts of chamois creme to the rider's pad. I'll bet it was Assos creme, too.
I use Bag Balm (try a feed or farm store). I put it on the areas of my butt that have been a problem in the past. I carry a small container with me and re-apply after the first 100 miles, then about every 50 after that.
Quoted: 2604 Post(s)
Liked 1,933 Times
Sounds sort of like diaper rash? If that's the case, there's two things you need to do.
First, get out of the cycling shorts as soon as possible after each day's ride, wash off (shower, if possible), and put on dry clothes. If you don't want to put on diaper powder, try some Anti-Monkey Butt Powder. (Search for it!)
Second, the goop. When you're clean and dry, try the Bag Balm. It helps my skin heal up overnight. If it's still tender the next day, put on the chamois butter before you start the day's ride.
And you don't really need anything over cycling shorts. If you're modest, slip the running shorts on when you get off the bike, but still try to hit the shower ASAP.
Quoted: 4234 Post(s)
Liked 2,949 Times
Are you rewearing the shorts without washing in between? If so, at the very least make sure they're getting very dry before going back on. Also, there's this magical stuff called Beaudreaux's Butt Paste. Never used it on myself, but it works wonders on my daughter's diaper rashes and we even have a song I made up about it that calms her down if she's fussy as we're getting her ready for bed. Great stuff, not too pricey, usually found in the baby department of any drug store/larger store that'd sell baby consumables like diapers or formula (grocery store, target, etc).
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Thanks for remembering this one as it is also crucial to prevent rashes. Not just cycling shorts either, the worst rash I ever had was from a brief rain shower soaking my jeans while laying foundation block around the house. The rash was so bad that time that it bled!
Bikes: Surley LHT
One more thing.Can't we call it riding shorts rash?
Bikes: S5 VWD & SL-7 S works Red.
Quoted: 52 Post(s)
I like Dz nuts cream. It has tea tree oil that is supposed to be naturally anti Bactria. It comes in a tube so it stays clean and a small amount lasts all day. I have to wash the areas that I apply twice to get it off.
It is not cheap but I like better than other creams.
deleteme
Bikes: deleteme
Quoted: 50 Post(s)
My last chamois shorts died 3-4 years ago and I've never looked back. Either unpadded spandex or ~95% nylon ~5% spandex boxers when it is warmer out. See REI: ExOfficio Give-N-Go Boxers.
I find tight spandex on the legs in warm weather just plain icky.
Bikes: 2006 Specialized Ruby Pro aka "Rhubarb" / and a backup road bike
Quoted: 7 Post(s)
Liked 13 Times
Clean bike shorts for each ride. Launder them in cool/warm water, use detergent without fabric softeners/fragrance (if possible), dry on low heat or hang dry. Make sure the detergent is completely rinsed out.
Snug fit so they do not slide around on your skin.
Do not wear running shorts over bike shorts when riding. Put them on after you get off the bike if you feel the need.
Stand up on the pedals from time to time to get some cooling/drying airflow.
Apply chamois butter to clean skin in problem areas before riding. Some people just need it on body folds, not the entire chamois.
On long rides, bring along some baby wipes (aka feminine wipes) and a small bottle of chamois butter; clean up and apply more cream at each pit stop. Meticulous hygiene.
Bikes: Surley LHT
Bikes: Surley LHT
As for the Chamois Buttr,people recommend so many different products.Chamois Buttr,Bag Balm,etc.I bought the Chamois Buttr because it was what I first read about here.Do they all do the same thing?And many recommend using powders.I guess different things work for different people.
And since I'm exposing my personal ailments here,I may as well come all the way out of the closet.NIPPLES.Is there something I can put on my nipples to prevent chaffing?Band aids are embarrassing when I forget and take my shirt off.
Bikes: Specialized Allez 09 turned commuter, Raleigh Olympian in the works, 10 other frames and boxes of parts I want to work on when I get the chance.
I don't see a problem with running shorts, I wear cycling shorts under baggies every day and have never had a problem for years
Liked 2,949 Times
sounds like the cause for sure to me.
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
If you're traveling and outside in a tent, then it means the clothes need to be washed and hang dried. Depending on humidity, you may need 3 pairs of shorts. That way when you rotate the usage, it will be completely dried. When you get off the bike after a ride, that's when you must shower and wear loose fitting clothes so that any excess moisture from the body does not have an opportunity to provide a breeding ground onto the existing rash.
Bikes: Surley LHT
In Real Life
Bikes: Lots
Liked 596 Times
One of the things that causes these rashes is the salt from your sweat. If you're sweating a lot, it is not a bad idea to wash yourself periodically throughout the ride. If you don't have water and paper towels, baby wipes can work.
And it is a good idea to sleep in something else ... bring a light pair of boxers or something.
If you do get a rash, and want something to clear it up quicky, try zinc oxide cream. You'll find it in the baby section of your local department store. Shower, apply the zinc oxide cream, put on the boxers ... and you'll be good to go in the morning.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Bikes: Surley LHT
In Real Life
Bikes: Lots
Liked 596 Times
The brands I would name would likely be Canadian or Australian brands ... just about anything that's zinc oxide would work. In Canada I might look for Johnson's & Johnson's products.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
