Best type of innertube
nee-fefanu
Bikes: gt compe but dont be hatin evry thing on it is new except the frame
I wanted to know wat type of innertube is the best the slime tube or the extra thick ive had both and the extra thick one never pops i should have popped my tire at least 7 times by now but i havent and the slime tube was good 2 but popped from a snake bite couldnt plug it up so wat do u think is the best ?
Thizzin in Spokizzle
Bikes: WTP LO-FI Brakeless,wit WTP bars and forks,Demolition Anorexia LHD, and Demo Crank, all custom...
I guess from what you just said the extra thick is what I would go with but instead of buying expensive innertubes once they pop I would just buy those kevlar tube protectors that thay have they are really nice my uncle uses them on his Specialized MTB and they protect the tire pretty good I dont know that they would protect the walls of the tire they pretty much only protect the bottom where most the thorns and stuff get the tube But, to make a long story short the kevlar tube protectors are really nice and less expensive in the long run!!!
i use the really thick ones and i've only popped one of the thick ones. I really like them - I used to have the one with the white glue insid of them. but theyre not as good as the thick ones. but the thick ones are heavy
be sensible
pro rider
Bikes: Mirraco blend frame
The basic $1.99 tire tube works for me. Inspect your rim strips and tighten any loose spokes also file down any burrs inside your rims.keep the tire pressure at maximum pressure and they should last for a long time.
member
Bikes: Solid AA
I just buy them in bulk from Albes and Empire. I only pop a few tubes a year, so most of my extras end up going to friends anyway.
