Replacing cup and cone BB with Velo Orange cartridge type
Old 02-13-12, 08:33 PM
yugdlo's Avatar
Bikes: 1975 motobecane Grand jubilee, and a rescued 1984 Raliegh Marathon, that my daughter is using at college
I have a Motobecane that came with a Stronglight competition BB; 118mm ISO taper spindle. I love the looks of the Stronglight 49D crank, but alas old age has crept up on me, and TA rings are just too darned pricey.
Soooo; for the past 3 years or so I have been running a Sakae SA crank, using it as a compact double, 48, 34 chainrings. The crank is JIS tapered but has seemed to work OK; I do occasionally have to tighten the non drive side crank bolts. I am thinking about getting one of the Velo Orange French threaded cartridge BB's and get the crank back on a Jis taper spindle. I still have the original spindle from the SA. It is stamped 3S; a quick visit to Sheldon Browns, vault o knowledge tells me it is 121.5mm long. This may be a rhetorical question, but I assume I will be OK to get the 122mm spindle option from VO, but wanted to throw this out to you all, see what you think.
yugdlo is offline
Old 02-13-12, 10:06 PM
auchencrow's Avatar
Quoted: 17 Post(s)
Liked 42 Times in 33 Posts
Why don't you just reinstall the 118mm ISO taper spindle and your 49D?
- Auchen
auchencrow is offline
Old 02-13-12, 10:16 PM
loose spoke's Avatar
Bikes: 11 steel, 1 scandium, 1 carbon
Quoted: 5 Post(s)
Yes, that should work, however, check to see if the spindle for the SA is symmetrical. If not, you may have clearance issues on the drive side with the VO which is symmetrical.
loose spoke is offline
Old 02-13-12, 10:34 PM
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
The 3S has one end 5.5MM longer than the other.
IF the long end was on the crank, you need a 127MM BB.
IF the short side "" then a 116MM (117)
EDIT-
You'll note that Sheldon's chart gives the symmetrical equivalent on the far right column. That is IF the DS is the LONG side.
Symmetrical equivalent is 52 MM + 2X MM, where X is the DS length.
Bill Kapaun is offline
Old 02-14-12, 05:43 AM
yugdlo's Avatar
the 49D is 42, 52: I'm running a 34, 48. The VO bottom bracket is cheaper than a set of TA chain rings, and I have not found a 34 tooth TA ring
yugdlo is offline
Old 02-14-12, 05:57 AM
yugdlo's Avatar
EDIT-
The longer side was on the drive side. Unfortunately VO does not have a 127mm spindle.
Let me ask this. The spindle that came off the donor bike is still in good shape, and it came out of a 68mm shell, would that spindle work in the Stronglight bb?
yugdlo is offline
Old 02-14-12, 03:39 PM
Yes, probably without any significant issue, but try it and see. The proof is is in 'le pudding....'
753proguy is offline
itf6
Bicycle Mechanics
3
08-24-16 08:43 AM
JBHoren
Bicycle Mechanics
8
03-13-16 11:53 AM
kehomer
Bicycle Mechanics
2
07-11-14 04:29 PM
jimmuller
Classic & Vintage
18
12-11-13 09:38 AM
eschlwc
Bicycle Mechanics
17
07-06-13 06:17 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
