Wood Vs Composite?
Wood Vs Composite?
Hi everyone!
So I was doing some research and came across the Renovo bicycle website and it got me thinking. With todays technological advancements could we ever see a wooden framed bicycle in competition with a frame made of composites? Sounds a bit bizarre but I was just wondering what your thoughts are on these wooden frames. I think they look great but as for competing with, say, carbon fibre I'm not so sure.. What do you think?
Lewis.
Lewis.
Bikes: Raleigh Grand Prix, Giant Innova, Nishiki Sebring, Trek 7.5FX
So ah...
Guess from what material the first bicycle was made!
Don't really need to guess, it was wood. Though that's not what I was asking, I'm talking about the modern day. Do you think we could see a wooden framed bicycle in the velodrome for example? Or even the Tour de France? Would be interesting to say the least.
Quoted: 14 Post(s)
Liked 13 Times
Wood has been used for boats, cars, airplanes, bikes, etc. Better materials and processes have been developed and largely supplanted wood for these purposes. Wood is really a great material for trees and I don't see trees going away from wood any time soon. Same for bamboo.
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,211 Times
And guess why they moved away from wood on the second bicycle ever made
Stuart Black
Stuart Black
Liked 4,211 Times
It also has some inherent problems with strength in different directions. In compression, i.e. pushed on from top to bottom, wood is very strong. That's why it's great stuff for studs in walls where it's used with the grain of the wood. But pushed on from the side. like you would for a down tube, it's not as strong by a huge factor. That's why studs are used standing up and not laying down. If you are going to use wood as a header in a wall, for example, you have to support it every 16" or make it really, really thick. A floor beam made of straight grain wood, for example, needs to be 12" by 18" to support a floor load. Even then, you have to orient the beam in a specific direction to gain the most strength.
You could reinforce the wood with various compounds but you still can't thin it out like you can with carbon fiber and retain strength.
Stuart Black
Stuart Black
Quoted: 1572 Post(s)
Liked 643 Times
When comparing frame materials people tend to lock onto one set of criteria and overlook everything else.
Gary Bontrager said it best: "Strong, light, cheap. Pick any two."
Loving the bamboo bike! That slingshot one is pretty cool too, not seen one of those before.
I can understand the point about about flex etc. I guess that wood is a tricky and not always reliable material, mass production would be a slow process with checking for defects and the like, not exactly the most cost effective solution.
So would any of you consider buying a wooden framed bike? Could aesthetics ever outweigh performance?
Bikes: 2013 Haro FL Comp 29er MTB.
Quoted: 1470 Post(s)
Liked 45 Times
Only a Calfee or a Bamboo of equal quality. Even they use CF for forks and bottom brackets and joints between head and seat tubes. My fear would be about getting a scratch and then the material gets wet. I have had slit drums made from Bamboo that have split over time from humidity and heat. Don't know if Calfee has solved that problem but maybe they have.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Quoted: 305 Post(s)
Liked 2,038 Times
Liked 4,211 Times
Not even technically. Bamboo is a grass and only very distantly related to gymnosperms and, while they are angiosperms, they are monocots rather than dicots like deciduous trees. Part of the reason that bamboo can be easily used for bicycle frames has to do with the morphology of the stem. Instead of being layers of cells, bamboo consists of long longitudinal fibers that are bundled together around a hollow core. The outer derailer cable for indexed shifters is a good model for what bamboo looks like.
Stuart Black
Stuart Black
Liked 45 Times
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
Renovo uses a proprietary laminate system where they hollow out the frame after they cut in half (they also weigh in around 4lbs).. A lot of the homebrew bamboo bikes tend to have foam left in the tubes and an epoxy coating to seal them, also hemp lugs do seem to be durable but the carbon fiber ones definitely are stronger if built right. But to answer if we're really going to see these frames in racing any time soon, no.
Don't know about the rest of you but I can say I'd never get on anything made of wood, moving on concrete, at more than a couple miles and hour. Engineering undergoes "natural selection" of concepts also, and usually the people who try to buck it are the ones who split their skulls open after their wooden bike frame finally has enough UV rays, dry rot, and humidity changes and breaks in half.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
Also, I would bet a wooden house collapsing on you hurts almost as much as a bicycle frame breaking undeneath you. Although I have never had a house collapse on me to check this out.
A combination, an And , rather than an either-or Vs,
Johan Museeuw , another retired pro bike racer involved in a bike brand
bearing their name,
has a Belgian made composite frame set made using a combination of carbon and Flax
in the weave,
Is said to be a bit more comfortable on the ancient Cobbled race courses
in the Flanders-Waloon & Belgian-French border regions.
https://en.wikipedia.org/wiki/Johan_Museeuw
https://www.museeuwbikes.be/
bearing their name,
in the weave,
Liked 643 Times
