Go Back  Bike Forums > Bike Forums > Framebuilders
Fillet over TIG Welds?
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 02-18-12, 10:50 AM
Hi.
I've bought a cheap custom Tig welded frame and would like to smooth out the joints and thought this would be a good oportunity to try out some fillet brazing. Is this a bad idea?
Thanks.
psee is offline
Old 02-18-12, 03:33 PM
mudboy's Avatar
Bikes: Ruckelshaus Randonneur, Specialized Allez (early 90's, steel), Ruckelshaus Path Bomber currently being built
Go for it. Just make sure you remove all paint/primer first.
mudboy is offline
Old 02-19-12, 08:56 AM
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,836 Times in 2,294 Posts
This method has been used to make lugs with (out of two tubes). Also at least GT has used this method to make frames with. Andy.
Andrew R Stewart is offline
Old 02-19-12, 05:28 PM
Bikes: Kirk
Liked 8 Times in 2 Posts
Very many years ago Jamis offered a bike that was tigged first and then had fillets laid of that. They advertised it as the best of both worlds. In reality the tig was bad and it was then covered with fillets that weren't much better and then lots of bondo to make it look good.
You may have issues with getting the fillets to flow and wet out as they should over tigged joints. It depends on what rod they used and how well it was cleaned when they welded it originally.
dave
Dave Kirk is offline
Old 02-19-12, 10:37 PM
Wont all the heat weaken the tubing? I thought TIG is OK since only a little of the tubing is heated, and brazed frames have the lug to add some strength, but Braze over TIG would seems to be sketchy
merlin55 is offline
Old 02-20-12, 04:12 AM
Thanks.
Yeah, maybe it's not the best idea. I think i'll use some fine filler instead.
psee is offline
Old 02-20-12, 04:24 AM
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 67 Post(s)
Liked 129 Times in 96 Posts
Filet brazing was developed when shortages of materials in wartime made the building of lugged frames difficult and it was discovered that this construction method was just as good although more time consuming than building a lugged frame due to close mitering that is required in the respective joints.
Sixty Fiver is offline
Old 02-20-12, 04:27 AM
Quoted: 67 Post(s)
Originally Posted by psee
Thanks.
This is a method that has also been used on quite a few frames and there are some notable frame builders who have also used filler to correct less then perfect brazing work or to get a more aerodynamic shape that would be impractical with brass.
By using filler you will not have to worry about affecting the existing joints or cooking the tubing... in some cases you may have to use a good amount of what is expensive brass which would involve longer heating cycles while filler can be done cold.
Old 02-20-12, 07:45 AM
Schwinn use to use solder as a cosmetic filler over the welded or brazed joint. Andy.
Old 02-23-12, 01:26 AM
Quoted: 33 Post(s)
Liked 4 Times in 3 Posts
If you just want to smooth over the welds, or would settle on that, you can tig silicon bronze.
I've used epoxy compound to fair tig weld and it works well everywhere but bicycles where there is a prejudice against doing it, though it is a great way to simply smooth stuff out if you aren't trying to prove anything.
I would keep the practice brazing on practice pieces.
MassiveD is offline
Old 03-06-12, 11:41 PM
Bikes: 8
Quoted: 7607 Post(s)
Lots of Stainless filler wire is used on Tig joints , make sure its plain steel on the bead , first.
fietsbob is offline
Old 03-10-12, 09:34 PM
is just a real cool dude
Henry III's Avatar
Quoted: 30 Post(s)
Liked 27 Times in 11 Posts
It's perfectly fine. Check out Herbie Helm's site as builds his own lugs in this same method. His lugs will blow your mind. I love this one piece head lug.
Check out his Flickr page as Herbie posts up quite a few photos of his customer builds step by step. Page 13 gives a nice group of shots of his custom lugs from tig welded to fillet brazed and overall form cut out.
https://www.flickr.com/photos/helmcycles/page13/
Helmcycles.com
Henry III is offline
Old 03-10-12, 09:37 PM
Randomhead
Liked 3,685 Times in 2,509 Posts
Herbie is not using TIG for his bilaminate construction
unterhausen is offline
Old 03-10-12, 10:06 PM
Henry III's Avatar
Quoted: 30 Post(s)
Sorry for the confusion as I got confused flipping through the pages in his album of his TIG'd lugs and the fillet brazed lugs. It's crazy looking at the pictures online and then seeing it in person at Doug's shop.
Old 03-10-12, 10:29 PM
Liked 13 Times in 13 Posts
I'm pretty sure Rene Herse (the new one) are making their 650b lugs with this method. I have a V/O stem made that way, and so far it hasn't broken...
Six jours is offline
Old 03-11-12, 05:10 AM
Mark Kelly's Avatar
If you want to clean up the appearance of the welds, a material you might consider is the German made Devcon Stainless Steel / Epoxy putty. This stuff is pretty commonly used for non-load bearing repairs in my line of work. It's pretty durable and takes a reasonable surface finish. It has about one quarter the density of steel or brazing filler, so for a given size of fillet this method will not add as much weight (if you care about such things). It isn't cheap.
If you primarily want brazing practice, that's a different issue.
Mark Kelly is offline
Old 03-11-12, 05:36 PM
tuz
Bikes: Eight homemade, three very dusty
Quoted: 10 Post(s)
Liked 12 Times in 7 Posts
If you have no experience brazing, there is a high change of screwing up with the torch. Better to find something else to practice on?
AFAIK, Rene Herse does TIG+fillet for the lugs, then uses silver to braze the tubes.
tuz is offline
calstar
Framebuilders
14
03-19-13 11:22 PM
rhnam
Classic & Vintage
17
04-25-12 07:06 PM
evilcryalotmore
Framebuilders
2
03-25-12 07:43 AM
look171
Framebuilders
11
01-26-11 01:16 PM
look171
Classic & Vintage
2
01-07-11 03:14 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
