Go Back  Bike Forums > Bike Forums > Winter Cycling
Recommendations for socks with Lake MXZ 300 boots
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Old 12-20-04, 10:36 AM
purple hayes's Avatar
I picked up a pair of Lake MXZ 300 shoes and I think I may be over compensating in the sock department or not using the right type of socks.
The ride this morning was 16°F. The commute is 15 miles each way.
I wore a pair of Thorlos :: https://www.thorlo.com/datadriven/view_product.asp?s=JLM
And a pair of these over the Thorlos :: https://www.nashbar.com/profile.cfm?c...eid=&pagename=
My toes still got cold after about 45 min. on the bike. I think it may be because of sweaty feet.
Are there better socks out there?
purple hayes is offline
Old 12-20-04, 11:26 AM
bac
bac's Avatar
Bikes: Too many to list!
Liked 3 Times in 3 Posts
I also have the MXZs, and they are awesome. I wear one pair of ski-socks underneath. When the temps dip well below freezing, and I'm going to be out in the cold for many hours, I also use chemical toe warmers.
I wonder if you're not cutting off circulation by using two pair of socks? That would account for the cold. However, sweat could also cause your feet to get cold. I'd try the ride sans the Nashbar wet-weather socks. They may be too clamy for your set-up. The Lakes are pretty much water-proof, so you really don't need that type of sock underneath.
Good luck, and please let the group know what you find out.
bac is offline
Old 12-20-04, 11:47 AM
iowarose's Avatar
What size Lake did you wear, relative to your normal cycling shoe size?
Toe compression is my problem, and I hope it will be fixed once I get the SPD sandals I ordered. The Lakes look great, but I don't have the $150 to spend on them right now.
iowarose is offline
Old 12-20-04, 11:54 AM
You need a new bike
supcom's Avatar
Liked 4 Times in 3 Posts
I would certainly ditch the nashbar socks to try to cut down on sweat.
I would consider a wool hiking sock and, if still too cold, a lightweight inner sock (cycling sock or hiking inner sock) to help move sweat from your feet.
supcom is offline
Old 12-20-04, 11:55 AM
I normally wear a 47 or 48, but I went ahead and got a size 50 (the largest they make) to allow for more toe room with thicker socks.
Old 12-20-04, 02:27 PM
Dude who rides bike
BikeInMN's Avatar
I wear medium weight Smartwool hiking socks down to around 20 without chemical warmers and I'm good for 3+ hours. Below that and I'll use toe warmers...
BikeInMN is offline
Old 12-21-04, 01:20 AM
Super Biker
Mtn Mike's Avatar
Bikes: 2014 Curtlo, 2006 Serotta Coeur d’Acier, 2005 Independent Fabrication Steel Delux, 2003 Surly 1x1, 2003 Surly Cross Check, 1986 Schwin Worldsport SS commuter, 1980's Mongoose Supergoose
Most of the I wear my lightweight summer time Sock Guy wool socks with my MXZ 300s. The MXZs have enough insulation that I don't need winter time socks. On a two hour ride at 15 F, my feet will be fine. Colder than that, or longer than that, and I'lll consider thicker socks.
Mtn Mike is offline
Old 12-21-04, 10:30 AM
Perineal Pressurized
dobber's Avatar
I usually just wear my run-of-the-mill thin wicking socks inside my Lakes. I've been quite comfortable down to about -10°F as demonstrated by my coworkers "I Dare You" ride of yesterday afternoon.
Everybody's comfort levels gonna be different.
dobber is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
