smallest 'big ring' on compact sram apex?
Can I put a 44T big ring on my sram apex crankset? I currently have a 50/34, want to take it down to at least a 46/34, prefer a 44/34. Is that possible?
thanks
thanks
Quoted: 86 Post(s)
i can safely say that i have never encountered a crank that would not mount a 44t chainring. i have a crank with a 144BCD and it has a 42t chainring on it.
beware: my newest crank was manufactured in 1995 or thereabouts!
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
SRAM Apex Compact is 110 BCD, so you could put a 34T on both sides if you wanted.
If you go much smaller on the big ring, it would probably help to lower the derailleur a bit.
I guess what im wondering more is would a 44T big ring even be compatible with the crank set (cranks are compact apex). If that works, im guessing the derailer could be adjusted properly? not a mechanic, so no idea!
thanks
thanks
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
yes, it's possible. just make sure you buy a ring for compacts and for multiple speeds.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
cycles per second
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times
You can certainly put a 44 110mm BCD large ring on the Apex. You may not be able to find a ramped and pinned one, though. I put a 44 Salsa ring on my 110BCD crank and run it as 44/34. You will also need to be able to lower your front derailer, ideally by 1.2cm. You may not be able to lower it this much if your frame uses a bracket-mount (aka "braze-on") front derailer.
bobonker
Bicycle Mechanics
3
01-24-13 09:50 PM
