how do [I]you[/I] install downtube friction shifters?
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Quoted: 59 Post(s)
Liked 22 Times
how do you install downtube friction shifters?
i'm concerned here with how you install and maintain downtube friction shifters on vintage 10-speeds. i like the idea of lubing all components (washers and surfaces) with the exception of the screw, where i use blue loctite or a similar non-destructive threadlocker. how do you do it?
ps: listen while you write
Bikes: 2007 Nagasawa with C-Record, 1992 Duell with Croce D'aune/Chorus, three Gazelles, M5 recumbent
Quoted: 47 Post(s)
Liked 25 Times
I use a small amount of grease on everything, even the screw. So far no problems.
I just lightly grease any touching surfaces that need to move against each other. I've never put thread locker on, but I'm going to start on future flip bikes(no more friction DT for me). I've had two instances now of bolts that loosen with shifting over time and then my bike wanting to drop to the smaller cog in back. It was a bit of an issue once when I was ~10mi and many hills from home after already riding ~20mi.
Thanks for the music.
i had to use threadlocker on my ofmega shifters or the screw would back out as you shifted. with grease (attempt #1) it would come loose enough to slip in a few shifts. dry, (attempt #2) it would last 10 miles or so before it needed tightened. with very low strength (purple) loctite the screws stay put and the bike shifts great.
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
I wonder if linseed oil on the screw threads would help stiffen them up, same as we do with spoke threads.
With the old-style Campy DT shifters, the pre-retrofriction ones, I found they worked better without any lube on the plastic washers and bushings that bore against the aluminum shifter drum. Eventually the aluminum parts would get a little rough from oxide buildup and the "stiction" tended to combat the ghost-shifting problem. When new and clean they were very prone to slippage, especially when standing on the pedals and flexing the frame.
Quoted: 59 Post(s)
Liked 22 Times
i've read online people sometimes cut up tiny pieces of rubber, like pencil eraser, for the threads. others use that thin teflon plumbers tape in lieu of grease. someone else used a condom. not a used condom. and not just any new synthetic condom, but the lamb intestine ones. or is it lamb skin? no, it couldn't be the actual skin. speaking of lamb, i wonder if cyclists in scotland have ever used haggis in their threads? any scots here?
Quoted: 556 Post(s)
Liked 132 Times
Erasers? Teflon? Lamb gut condoms? Man, no offense but I believe you're over-thinking this. Lightly lube the moving parts, put them together and go. Tighten the screws before every ride.
Quoted: 59 Post(s)
Liked 22 Times
hmm. hmm. so ... you're saying just use lube and not haggis? hmm. well, i'll think about it, but that sounds kind of crazy.
Quoted: 556 Post(s)
Liked 132 Times
I don't know. Maybe haggis skins are the new Phil lube! You may be on to something here.
Oh, and, much as I hate to channel the spirit of RIV ...but a smear of beeswax on the screw threads might help.
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
