Go Back  Bike Forums > Bike Forums > Winter Cycling
Nokian Mount and Ground W160 vs Hakk. W106
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Old 12-27-04 | 08:02 PM
My wife ordered W106s for Christmas but the LBS got W160s instead. I found out when I opened my present and am now wondering if I should keep them. I wanted the W106 b/c the studs are in the center and seem like they would give better control on the ice; the W160 has studs that are further out to the sides. I will be using these for daily commuting. Has anyone used both the W106 and W160? If so, which did you prefer? I know that you can supposedly lower the psi on the W160 to get the studs to contact, but that would give a squishy, less efficient ride than fully inflated W106s. Any suggestions? How do the tires corner on dry pavement? If I mount mine and try them I can't take them back.
Thanks for any info.
jlgerhar is offline
Reply
Old 12-28-04 | 12:44 PM
Vision-'s Avatar
Look out!
20 Anniversary
Bikes: Specialized Hardrock, Raleigh Record Ace, Argon 18 700.5
I actually had a similar situation, I ordered 106's from my LBS, but 160's showed up instead. Because it took so long to find a set in the first place I kept the 160's. I use them for daily commuting as well, and they're great. Amazing traction on ice, all the studs make contact going straight (I run them at 40 psi). I am fairly large though, 6'2 210, so if you're significantly lighter, that may factor in. I go over a lot of dry pavement on our main thoroughfares, and cornering has been fine. I can't comment on the 106's because I have not tried them before.
Vision- is offline
Reply
Old 12-28-04 | 02:46 PM
Ivan Hanz's Avatar
Man of Leisure
Peter White describes the differences eloquently here:
https://www.peterwhitecycles.com/studdedtires.asp
Ivan Hanz is offline
Reply
Old 12-30-04 | 10:02 AM
Well, I decided to just keep the 160s and you are right, they are great on the ice and even hold their own off road.
jlgerhar is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
