Dualdrive II on 130mm frame
Dualdrive II on 130mm frame?
Can Dualdrive hub be slimmed down to fit 130mm spacing? I see there are two nuts on both sides that could be replaced with nuts 1/2 as thick perhaps?
Go to the source :https://www.sram.com/service/sram/259
No, aluminum. Anyway, I figured it out...after measuring the frame it's really 132 so all I need to do is find thinner M10x1 nuts or file 1.5mm off of each. I probably could stretch it but I do not want to put unnecessary stress on the welds.
Thanks for the link fietsbob.
