Help with frame
Help with frame
Hi, I was thinking of buying a new fit van homan frame. I have read that the frame comes in three types a 20 , 20.5 , and a 21. I was just wondering if some could tell me the differences in these sizes and what i would notice in riding them. I am around 5.8 feet and weigh around 9.5 stone (65 kg i think) if that helps or matters at all. thanks MAVE
I'm 5'8" and ride a 20 inch top tube.
that is what those numbers mean (20, 20.5 and 21)
the longer the top tube, the more room you have between your bars and seat/cranks. most people run 20.5 or 21 but I like a tad smaller frame because I'm weak.
Bikes: Wethepeople
Originally Posted by rice400
in america we weigh ourselves in pounds
every one else uses the metric system so they weigh themselves in kilograms
It's the same thing.
Yeah you should probably feel better on a 20.5" frame maybe bigger, although I'm 6'2" and ride a 20", but i just ordered my Federal T-nez in 20.5.
Top tube length is in inches and is ENTIRELY personal preference.
There is no reason someone 6 and a half feet tall can't ride a 20 inch top tube or smaller, it is just personal preference. The length of a top tube affects how responsive the bike is in the air. The longer it is, the more stable it is, the shorter, the more responsive it is.
In the end, it ends up being personal preference what you like and what you get used to. I would recommend something in the middle (20.5) if you are unsure so you can get a feel for what you do like as far as top tube length. You may end up feeling like the bike is to sluggish to respond - to stable - so you may go with something shorter. Or... you may think the bike is to twitchy and go with something longer later on.
It has very little to do with rider height though and a lot to do with how the bike feels to you - personally. So, when someone says 'this is what a person your height/weight should get', they are wrong. You need to get what you feel comfortable on and if you are unsure then you may want something in the middle to start off on - unless you think you know you want something longer or shorter.
