Split NR/SR RD pulleys.
Old 04-11-12, 02:52 PM
gearbasher's Avatar
Quoted: 452 Post(s)
Liked 904 Times in 383 Posts
I have a few NR/SR rear derailleur pulleys that are in great shape, but have the typical split down one side. Has anyone ever tried repairing them? If not, what do you guys use as an inexpensive replacement? Thanks.
gearbasher is online now
Old 04-11-12, 06:29 PM
miamijim's Avatar
Quoted: 413 Post(s)
Liked 109 Times in 78 Posts
Can't be fixed.
I use standard Shimano TY-series as replacements.
miamijim is offline
Old 04-11-12, 06:43 PM
CL Addict
b dub's Avatar
Bikes: '50s Leon Cattrysse - late 50s Raleigh Lenton Sports - 1960/61 Raleigh Lenton Grand Prix - '72 Canadian Tire Company Supercycle - '74 Raleigh International - '83 Nishiki Cresta - '84 Centurion Turbo - '86 v. Herwerden (Chesini) - '87 Specialized Sirr
Quoted: 85 Post(s)
Liked 96 Times in 59 Posts
If you don't replace them, what happens?
b dub is offline
Old 04-11-12, 06:56 PM
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times in 27 Posts
I was thinking the same with the split jockey wheels on my 1st gen NR RD lately, but after I examined the split pulleys closely, I decided that there is no way to close up the crack as it looks like that the plastic had actually shrunk that if you can even glue it back together, it will most likely crack again at the same spot or a different part of the jockey wheel.
Genuine campagnolo Replacements costs way to much out there at sometimes over 40 bucks EACH. Fortunately, my LBS had nicely made repros supposedly machined up by the owner's friend and I bought a set of 2 this weekend for 30 bucks. They look pretty good, actually. Still a bit expensive for what they are, but at least they are not cracked and maybe the more modern plastic material will last longer than the genuine Campy crackmaster jockey wheels..... I'll post a pic of them tomorrow evening when I get back home from my project site visit.
Chombi
Chombi is offline
Old 04-11-12, 07:05 PM
Chrome Freak
Rabid Koala's Avatar
Bikes: 71 Chrome Paramount P13-9, 73 Opaque Blue Paramount P15, 74 Blue Mink Raleigh Pro, 91 Waterford Paramount, Holland Titanium x2
Liked 26 Times in 14 Posts
I replaced a pair with aluminum pulleys on one of the bikes I used to own, and then wondered why it seemed to shift better than my other Nuovo Record bikes. It must have been the pulleys.
1971 Paramount P-13 Chrome
1973 Paramount P-15 Opaque Blue
1974 Raleigh Professional Blue Mink
1991 Waterford Paramount
Holland Titanium Dura Ace Group
Holland Titanium Ultegra Triple Group
Rabid Koala is offline
Old 04-11-12, 07:07 PM
rootboy's Avatar
Quoted: 556 Post(s)
Liked 132 Times in 78 Posts
Very interesting Chombi. Machining them out of plastic? Looking forward to seeing those. I've been tempted by the SOMA Fab alloy ones, but haven't pulled the trigger yet.
rootboy is offline
Old 04-11-12, 07:42 PM
rain dog
mainstreetexile's Avatar
Quoted: 16 Post(s)
Liked 8 Times in 6 Posts
I had a NR rear derailleur with a set of bullseye pulleys on a bike for a while, seemed to work very well:
Sealed bearings, should last for a while. I believe these were a common upgrade on NR derailleurs, you can still find NOS ones on ebay here and there.
mainstreetexile is offline
Old 04-11-12, 07:47 PM
rootboy's Avatar
Quoted: 556 Post(s)
Those are nice too. The black ones go for almost as much as NR pulleys on ebay. One other option is to find a donor derailleur and naturalize its pulleys. I've used some from an old Valentino. Not as fancy as the Record ones but they work.
rootboy is offline
Old 04-11-12, 08:08 PM
Procrastinateur supreme
CrankyFranky's Avatar
Bikes: Enough bikes...for today!
Quoted: 34 Post(s)
Liked 3 Times in 2 Posts
Originally Posted by mainstreetexile
... a set of bullseye pulleys on a bike...should last for a while.
I've had mine on my NR for over 30 years! The aluminum teeth are now just points, but THEY STILL WORK!
CrankyFranky is offline
Old 04-11-12, 09:14 PM
gearbasher's Avatar
Quoted: 452 Post(s)
Chombi
I was thinking of just filling in the crack with epoxy or JB Marine weld and not trying to actually close the crack. Has anyone tried that?
Old 04-11-12, 09:18 PM
Drillium Dude's Avatar
Quoted: 2588 Post(s)
Liked 4,824 Times in 1,709 Posts
That would work to close the crack, but the gap would still be there - as in, it will throw off the spacing between the teeth. Chain run will be affected. No solution, unfortunately, other than new pulleys.
DD
Drillium Dude is offline
Old 04-12-12, 02:11 AM
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1565 Post(s)
Liked 1,295 Times in 865 Posts
b dub asked the critical question: "If you don't replace them, what happens?"
The answer is, nothing. The pulley remains strong.
The cracked pullies last for the life of the teeth, and the tooth-spacing issue resolves itself via normal wear, and to a large extent that bit of needed tooth "clearancing" has already occurred from normal wear when a crack appears.
The pulleys seem to crack from shrinkage, and once cracked the stress is removed.
These are much better than the Simplex pulleys that crack because those crack in such a way as to lose several teeth at a time.
I like Huret pullies with teeth, the ball-bearing ones with adjusting cones. The teeth never break and the hole size allows them to be fitted to Suntour derailers.
They will run much smoother than stock with the addition of normal grade25 ball bearings, 1/8" I believe.
Has anyone seen a Campag pulley actually break?
dddd is offline
Old 04-12-12, 03:18 AM
Michael Angelo's Avatar
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times in 22 Posts
I've used "Cynergy" sealed pulleys, "Bullseye" sealed pulleys. Both work fine, but you have to lift up the plastic dust cover and repack them. They've been sitting around for almost 30+ years and the grease in them is petrified.
Michael Angelo is offline
Old 04-12-12, 07:03 AM
Chombi's Avatar
Quoted: 150 Post(s)
For me personally, I'll never feel comfortable about riding a bike with cracked RD jockey wheels of any kind lest it asplodes and possibly jam up the chain in the RD and cause the RD to get wrenched or bent up into the spokes.......guys who ride such cracked jockey wheels might call me paranoid, but at least I don't have it in the back of my mind when i ride.
BTW, I also noticed that the cracked jockey wheel on my NR RD has other small cracks forming at other parts of the wheels in addition to the one big split that's already on them, so it's really a progressive thing that happens with the Campy Jockey wheels and not just one big split.
Chombi
Chombi is offline
Old 04-12-12, 08:28 AM
Quoted: 78 Post(s)
I'm afraid that they will crack in half.
Old 04-12-12, 11:28 AM
Grand Bois's Avatar
Quoted: 443 Post(s)
Liked 27 Times in 25 Posts
I haven't had trouble with Campy, but I've replaced my Simplexes with Bullseyes. I won't recommend them, since I checked eBay to see what they're going for these days. The vintage bike hobby is becoming too expensive for me.
Grand Bois is offline
Old 04-12-12, 01:43 PM
dddd's Avatar
There ane now some Chinese, alloy, 10 tooth ball-bearing pulleys being sold for reasonable price on Ebay.
Available in several colors.
I bought a couple of different versions of these, and no problems, but on one I had to drill out the metal covers from 5mm to 6mm.
At least the inner bearing race had the right diameter hole already.
dddd is offline
Old 04-12-12, 02:20 PM
gaucho777's Avatar
Quoted: 834 Post(s)
Liked 2,125 Times in 554 Posts
I love Bullseye pulleys, though they are quite expensive. I tried some of the less expensive drilled & anodized alloy pulleys from Taiwan, but I found them a bit loud.
-Randy
'72 Cilo Pacer • '72 Peugeot PX10 • '73 Speedwell Ti • '74 Nishiki Competition • '74 Peugeot UE-8 • '86 Look Equipe 753 • '86 Look KG86 • '89 Parkpre Team Road • '90 Parkpre Team MTB • '90 Merlin Ti
Avatar photo courtesy of jeffveloart.com, contact: contact: jeffnil8 (at) gmail.com.
gaucho777 is offline
Old 04-12-12, 02:33 PM
dddd's Avatar
I've had a few different brands make noise when new, but all broke in over time.
Have you checked your derailer hanger alignment? The lower pully often makes a lot of noise (usually when using the big ring) on bikes with even a mildly bent hanger, and new metal pulleys could make it very loud.
dddd is offline
Old 04-12-12, 08:20 PM
Bikes: Rivendell A.Homer Hilsen, Paramount P13, (4) Falcon bicycles, Mondia Special, Rodriguez Tandem
Quoted: 53 Post(s)
Liked 14 Times in 9 Posts
I agree with dddd; I lived in fear that my cracked pulleys would break completely but I was also intrigued to see if they would. This lasted for decades.
MKahrl is offline
Old 04-12-12, 08:54 PM
The SOMA ones are CNC machined from plastic, but have sleeve bearings like the original Campagnolo pulleys. And retail for about $30/set. They are black. Probably what he's talking about, if I had to guess from here....
753proguy is offline
Old 04-12-12, 10:31 PM
Chombi's Avatar
Quoted: 150 Post(s)
Here's comparo pics between the machined (CNC'd, according to the shop owner) repros I got from my LBS this weekened to replace the badly cracked originals on my 1st gen NR RD, and the Genuine jockey wheels that's on my pat.83 NR RD:
Pat. 83 NR RD with original jockey wheels.
Pat.-72 1st gen NR RD with the CNC'd black plastic jockey wheels.
Repro
Genuine. See that thin black line on it, going from center and right to the edge of a tooth? It's not a crack!
The obvious differences are, the larger diameter dust caps on the repros, the absence of a groove on the repro bronze bearing bushing (the 1st gen NR bushing did not have grooves either.), and the deeper teeth on the repros. The reproe also seem to be just a smidgen thicker than the genuine campy jockey wheels too. The tooth profiles are also a bit different with the repros reminding me of what Simplex jockey wheel teeth look like.
One interesting thing I just noticed too is the genuine wheels have a dark line at the same spot on the wheels which seems to match the location of the crack on the bad ones from the 1st gen RD. I think it could be a sort of moulding seam where the injected plastic material meets up in the mold during injection. Could this be a built in weak spot on the jockey wheel where that big crack appears all the time??
I won't know how well the repros will work till I get my project bike on the road. but I think it should be OK as the wheels look very well made and there is no excess slop on the bearings.
BTW, I was going to use the original 1st gen cracked jockey wheels for the pictorial comparison, but dang! I think I might have thrown it away! Whydiedoodat?!
Chombi
Chombi is offline
Old 04-12-12, 11:51 PM
Quoted: 3464 Post(s)
Liked 2,829 Times in 1,995 Posts
Those machined pulleys appear like Soma Fabrications units, alas a quick review of their site just now shows no longer listed as a product.
repechage is offline
Old 04-13-12, 12:36 AM
gearbasher's Avatar
Quoted: 452 Post(s)
Originally Posted by miamijim
Can't be fixed.
Are these the ones you use?
https://www.amazon.com/Shimano-Derail...048045-7406858
Old 04-13-12, 06:20 AM
rootboy's Avatar
Quoted: 556 Post(s)
WHA!? Dang, shouldn't have hesitated in ordering some. But then, if they've stopped offering them ...I wonder if they had problems with them cracking?
You know, I thought I read somewhere someone was making after market Campy copies in alloy and I had assumed it was Soma Fab. Guess not.
rootboy is offline
