Who keeps two chains for a bike?
I'm thinking of having a container full of some lubricant (probably the kind I use) and keep one chain in it. Then once a week, two weeks, etc. I put it on the bike and take the one that was on the bike and put it in the container for a soak.
Thoughts? Valid? Dumb idea?
Quoted: 3375 Post(s)
Liked 5,514 Times
There are a number of people here who rotate through three chains per cassette.
I'm sure one will chime in shortly.
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
Close, but not quite how you should rotate them, IMO. Don't keep a jar of lubricant, as it won't get the chain clean. Try a jar of mineral spirits instead, and give the dirty chain jar a shake every day or so to really get the old grit out of the rollers. Give it a couple rinses in clean spirits before drying it off in front of a fan or with some spray air to quickly evaporate any remaining spirits from the rollers. Then lube it up with a drop of whatever your favourite is per link. (I use Finish Line Wet most of the year up here in the PNW.) Install, decant your settled spirits to a clean jar, and soak the dirty chain.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
Bikes: 2010 Felt DA, 2012/6 Felt F5, 2015 Felt AR FRD
Quoted: 27 Post(s)
I don't want to rain on anyone's ideas, but I honestly don't think it will be as helpful as you hope. I'm assuming the goal is to extend the lifetime of the chain, but I think keeping one on the bike, and keeping it lubed would be more practical, and beneficial than swapping them. For one, it's a lot of work to do every two weeks. Second, I would say that relinking a chain that often would increase the risk of damaging it.
Those are just my thoughts, do as you wish.
My question is: Presuming the chain in use is periodicaly lubricated, what does rotating through multiple chains on a single bike achieve that simply using a chain to the point of replacement does not? (without getting into the entire debate about the advantages vs. disadvantages of using a rotary brush cleaner)
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
Pedals, Paddles and Poles
Bikes: Santa Cruz Tallboy, Ridley Noah, Scott Spark 20
Quoted: 1233 Post(s)
Liked 69 Times
Soaking a chain in lube is overkill, but if you don't mind the expense it should be great for the chain. When riding a bike the chain should be nearly dry to the touch on the outside. The rollers and links are what need lubrication. Too much lube attracts dirt and fouls the chain pretty quickly.
You have a good devotion to the condition of your bike. Personally, I think that a clean chain is one of the best improvements you can make for power transfer. There is a good discussion of chain lubing in the Mountain bike thread, two of them in fact. You might check them out.
I think its disgusting and terrible how people treat Lance Armstrong, especially after winning 7 Tour de France Titles while on drugs!
I can't even find my bike when I'm on drugs. -Willie N.
If using hardened shimano pins for your chain connection, I would recommend against frequent removal. If using quick links, I would suspect the removal cleaning, drying, lubing would actually require more time than outlined above.
Sorry, but, no free lunch on this one. Just keep a couple rags handy, a bottle of lube and maybe a mechanical chain cleaner. That is the quick solution. Some might suggest the removal route is a "better" solution. But, I can't imagine it being a "quicker" one.
I can understand those individuals who see soaking a chain in solvent as an effective means of loosening grime. But, even then I question if they're any more effective at getting material out of the rollers and pins than simply using a chain cleaner would have been. Either method involves the neccessity of then thoroughly drying the chain and relubing.
To remove a chain, just to let it soak in lube?
I think you CAN do a better job cleaning/lubing a chain by taking it off the bike compared to doing the maintenance insitu, but for me, the hassles of breaking a link each time and re-threading the chain is more trouble than it is worth. Having said this, I do occasionally take my drivetrain apart (every year or so) for a thorough cleaning.
As to having a 2nd chain so one can be on soak while the other is in use, I doubt a chain that soaks in solvent/lubricant overnight does that much better than one soaked for a few minutes while you're doing other bicycle maintenance. Seems simpler just to remove it, clean it, lube it, and return it to service and not worry about a 2nd chain.
- Mark
- Mark
SuperGimp
Alright, I'll chime in too, why not.
If you really clean your chain well, you need to clean it, rinse it, let it dry and then lube it. If you left the chain on the bike, it's probably not as clean as you think. Messy, and takes a while.
If you remove your chain (I just bought a wipperman removeable link for my SRAM 10 speed chain) and soak it in cleaning solution, then rinse it, then install it and lube it, your chain will be as clean as if you just got it out of the package.
I like both methods, but for me and scenario #2, my EXTRA chain can be used while the first one is at the chain spa. I tend to remember to do bike maintenance right before I want to go riding, so there's that.
Personally I usually clean my chain on the bike. It is perfectly possible to get it properly clean, and the more often you wipe it down the better - it's not a long job. And many people's chains are dirtier than they need be because of too much lube. Once you have lubricated it, wipe the excess off. It's only the pins you want lubed, leaving some on the outside just means it picks up grit.
However, my main comment regards breaking the chain. I very rarely break a chain, doing so only if there's a problem. If I have to remove a chain from a bike with derailleur gears, I remove the jockey wheel from the rear mech, and the small screw with spacer at the rear of the front mech. The chain then comes off the bike without your having to disconnect a link. This takes no longer than it does to use a chain tool, and while it is slightly - but only slightly - less convenient than a quick link, it is also cost-free and avoids the slight potential for failure.
Given that I can get a KMC Z610HX chain with a 2500 pound tensile strength for $10 - $12, I don't see much point into spending loads of time and money on extensive cleaning, etc. Just swap in a new one every 4 months or so, periodically dripping on a little ProLink. Maximizes chainring and cog life.
(Think about the path the chain takes through that rear triangle.)
Yes, sorry. Actually it's not my credibility thats the problem, but my ability to express myself. Yes the chain still passes through the rear triangle. My point is that the issue most people raise with regard to chain cleaning is access. What I describe gives you ready access to the whole chain plus allows you, without breaking the chain, to remove the other bits of the drivetrain for maintenance, repair, replacement etc. There is only rarely a need to completely remove a still-serviceable chain from the bike.
If I have to remove a chain from a bike with derailleur gears,..... . The chain then comes off the bike without your having to disconnect a link. This takes no longer than it does to use a chain tool, and while it is slightly - but only slightly - less convenient than a quick link.
2 Fat 2 Furious
Bikes: 2009 Specialized Rockhopper Comp Disc, 2009 Specialized Tricross Sport RIP
I was also considering the wear and tear on the chain by taking it off and on so often. My main goal is to make sure it is both clean and really lubed up because at times it is a struggle to get on the bike, let alone properly take care of it. I was hoping by doing this I would do the best I can with the time I have. Right now when I get off the bike I park it in the garage and go inside to run to some other activity. Before long my bike is overdue for some loving.
"For a list of ways technology has failed to improve quality of life, press three"
Yes of course I do, and what I said was foolish. But it arises from the fact that I almost never feel the need to remove the chain from the frame. For me the issue is almost invariably how best to separate it from the rest of the drivetrain.
Wiping your chain with a rag on a weekly basis, applying a drop of oil per link, spinning the cranks a few times and then wiping chain again with rag takes but a few seconds. Maybe, 2-3 minutes at the most. Hardly any more than pumping the tires.
- Mark
- Mark
