Brooks Seats
Brooks Seats
So I ordered the B17 Imperial last week. I had been wanting a leather seat, and was starting to get numbing issues after about 30 miles. Has anyone had experience with these? And has it helped?
Thanks
Thanks
Quoted: 5888 Post(s)
Liked 3,471 Times
Some people swear by leather saddles and others swear at them. They take time to break in so it's not suprising your butt hurt at 30 miles. I broke in a B17 once and it took time.
SuperGimp
What was numb? Don't be too specific mind you but maybe you have the saddle tilted in the wrong direction somehow. What kind of bike did you put it on?
From what I've heard, those Brooks saddles are comfortable immediately and become sublime when they're broken in. They shouldn't be causing numbness or pain right off the bat.
Do I use too many commas?
Bikes: Giant Yukon SE
My B17 was comfy out of the box. I suspect that you may have and adjustment issue.
I read the OP differently than the responses, I think. It seems to me like the OP was experiencing numbness issues so they ordered the Brooks in hopes of alleviating it.
I haven't used an imperial but my impression is that the cutout is intended to alleviate pressure on those sensitive areas as well as allow the saddle to move more.
Correct kj - I have not received the saddle yet. Was supposed to come this week, but the company I ordered it form shipped it the wrong way. I am going to try to tilt the current saddle a bit more forward until the Brooks arrives. I had a pretty aggressive drop on the bike, 5+ inches, that I have lowered a little - about 4" now. Hopefully the combination of those will help.
Bikes: 2009 Rocky Mountain RC30 D
With that kind of drop you may well find the standard B17 Imperial too wide?
They do make a narrow version as well.
https://www.brooksengland.com/catalog...rrow+Imperial/
Watching and waiting.
Bikes: Trek 7300 Trek Madone 4.5 Surly Cross Check
Quoted: 11 Post(s)
I have 3 B17's and two things about them are 1.) The frame rails are short so getting a seatpost with the proper setback for you is more critical. 2.) The seatpost needs to be continously adjustable for tilt. Like a two bolt design. Just a 1/4" adjustment on the nose can make a big difference.
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Santana Noventa Tandem, Fisher Supercaliber Mtn. Bike
Quoted: 14 Post(s)
Liked 11 Times
Most people who have serious issues with brooks are adjustment related.. You need to use a level when adjusting the saddle - eyeballing it does not cut it.
Most brooks b17 user prefer a saddle with a fraction of upward tilt. I did not have any issues with the B17 in terms of breaking in - the saddle just got better over time.
You will read a million ways to soften the saddle - a better term should be RUIN YOUR SADDLE. You do not soften brooks saddles. Use proofide or Obernaufs on the saddle. One coat top and bottom - wipe top clean..
The saddle will feel slippery - slippery is hard to get used too at first - just remember slippery equates to little friction.. No friction is GOOD.
Just adjust - ride and enjoy.
You will need a seatpost with at least 20mm of setback - fsa makes a good one - the best is velo orange seatpost but only comes in 27.2
https://store.velo-orange.com/index.p...g-setback.html
Quoted: 12192 Post(s)
Liked 1,495 Times
I have an Imperial.
It needs little break in because the slot lets the saddle flex.
It needs no softening for the same reason.
A pic of you on the bike from the side with the facing leg as far down as the pedal allows
might help.
But I think what you need is to slide the saddle forward.
Sometimes a tiny bit of nose up helps.
It's a nice saddle, spend some time fiddling with the position.
If that doesn't work, consider the new Selle anatomica saddle.
might help.
Liked 1,495 Times
The B17 seems designed for a very upright riding position. I put a couple of hundred miles on one before returning it. The bike I was riding had a 3-4" drop between the saddle and handlebars. When sitting bolt upright, the B17 was almost, but not quite, comfortable. Lean forward much and it became downright painful. I'd rate it as the second-worst saddle I've ever tried. Brooks makes other leather saddles that are more appropriate for bikes with a lot of saddle to bar drop.
A B17 is meant for a bike where the bars are close to the level of the saddle.
I'd be surprised if he likes it.
I wonder if he should send the package back unopened.
SERENITY NOW!!!
Bikes: Haro Vector, IRO Rob Roy, Bianchi Veloce
I had the same issues w/ the B17 on a roadie w/ saddle to bar drop. IME, it's better for more upright seating position. For more aggressive drop, I'm using the Brooks Swift. Not as comfortable as the B17, but more comfortable than all the other Specialized BG and San Marco saddles I used before.
HHCMF - Take pride in your ability to amaze lesser mortals! - MikeR
We demand rigidly defined areas of doubt and uncertainty!
Quoted: 14 Post(s)
Liked 11 Times
I use the Team Pro's on my road bikes and b17 on my MTB and Cross Bike.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
I run a Brooks B33 on my cruiser and it keeps getting better and better the more I ride on it!!!!!!
Leather saddle can/will absorb moisture to stretch this way and that until it's so "your butt" that you won't ride on anything else.
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
You guys got me thinking I should reconsider, but I think I am going to try it out. I have a decent drop, but I think that the seat should work for my build, and my bike setup. My current seat has felt a little narrow for may sit bones and the Brooks is about 1" wider. Will find out this week.
I really like the seat post suggestion, and I think I will get one of those and a matching stem.
Hopefully I can have an update next weekend.
Bikes: 2009 Trek Soho
I had issues too and my LBS said it was because the Brooks (esp Imperial) is too flexy instead of giving you the firm pedaling platform of a modern saddle. I thought it was hogwash at first but agreed to try a Specialized Romin Expert. Pain vanished, power improved, and I sold the Brooks the following week. Haven't missed it.
The Left Coast, USA
"...I had a pretty aggressive drop on the bike, 5+ inches..."
Pretty good bet you've ordered the wrong saddle. Although I like B17 standard and N for the right bike, that profile doesn't work in a rotated position. I think you are setting yourself up for more misery.
Bikes: 2012 Surly LHT, 1995 GT Outpost Trail
Love my Brooks. I've got two and both were comfy out of the box with no break-in required. I have a theory that heavier people do not require break ins as much as lighter people, as most people I know who didn't need any breaking in tend to be uberclydes such as myself.
collector
So I got the saddle in the mail Wed. looks very nice, proceeded to treat the leather and begin the modifications. I cut the lower part of the saddle off just below the "Brooks" emblem, basically the area with the holes for the laces. I will be adding holes for the laces after a few weeks of riding once it is broken in a bit more.
Received the Velo Orange seat post yesterday and installed everything, put on the trainer and made adjustments. (thanks for the suggestion socalrider!) I definitely needed the new seat post as the old one would have put me sloping way too far forward, ended up getting matching stem as well.
Fitting seemed best with the saddle perfectly level and a bit further back. Adjustment are easy on the VO post. On the trainer, the saddle felt pretty nice, even in the drops. It is a little slippery, and the cutout felt odd at first but I was just in running shorts. in the cooler months, cold air from the bottom may cause issue, but that should be an easy quick fix.
I am actually glad I stuck with the B17 as my sit bones are fairly wide, and I did not want to look like my a$$ was eating the saddle. So far I am optimistic that it will work well, as the comfort was better after the first 20 minutes of pedaling.
This weekend I will take it out on longer rides, a truer test (hopefully I will not need further adjustments, but doubt it).
It definitely looks great, and so far I am super happy about the purchase. If it does not work, I can always get a different saddle, and put this one on the wife's bike
