Ultegra/105 Chainring and Tiagra Derailleur
Ride the Road
Bikes: Surly Cross-Check; hard tail MTB
Liked 5 Times
My front chain rings are dying. I currently have 36/48 chain rings and a Tiagra front derailleur on my Surly Cross Check commuter. There are some good deals on 39/52-53 Ultegra and 105 chain rings on Nashbar and Performance. But the Ultegra ring says it works with "105, Ultegra and Dura-Ace." It does not mention Tiagra. My Tiagra front derailleur w/ bar-end shifters is doing just fine, so I see no need to replace it.
I put 4K+ miles a year on this bike in all weather conditions, oven carrying a load.
Other than having to clamp the derailleur a little higher, is there any reason it could not accomodate the Ultegra or 105 part?
I could also upgrade to a 105 or Ultegra front derailleur for $20 or $30, but would those work with my bar-end shifters? I also see no reason to upgrade when what I have works just fine. I am not prepared to spend the $$$ to upgrade to brake-lever shifters.
Edit: Thanks for the answers.
Bikes: paratrooper, bullhead, cdale bad boy
It should work fine with the Tiagra front dr. I run a Tiagra fron on my lemond cross and am using some the Nashbar stronglite chainrings 46/36 with no problems shifting. Before this I was running an Ultegra 52/39 on the bike and had no problems at all. Where you occasionally get into trouble is with the chain/rear dr. combination and non 9/8 speed chain rings.
