stripped seatpost clamp bolt, help!
Bikes: Cervelo S3, Dolan Pre-Cursa
i was wondering if any of you have ever experienced a seat post clamp bolt (allen head) stripping to the point where you can't remove it. i need to get the post out of my frame, but can't because i can't loosen the bolt. i have a new clamp to replace this one, so trashing the clamp isn't a big deal. i thought of cutting the bolt in half with a dremal tool or hacksaw (there is enough room to get in there to cut it without damaging the frame or post), which seems like it would release the clamp allowing me to remove it. do any of you have a better idea on how to do this? any help would be greatly appreciated.
Quoted: 114 Post(s)
Liked 119 Times
Originally Posted by infestedguy1
i was wondering if any of you have ever experienced a seat post clamp bolt (allen head) stripping to the point where you can't remove it. ...
sorry, shouldve clarified, the allen head socket is stripped. the threads and all are fine, just useless since i can't get a wrench to take the bolt out. so yeah, the head socket itself is messed up.
lover ....
Drill out the allen bolt head using a 5.5mm or 6.5mm drill bit (depending on whether you used a 5mm or 6mm hex key on it initially. You will be surpirsed how easily it will drill out. That will be a lot easier than trying to cut the bolt.
Quoted: 114 Post(s)
Liked 119 Times
Sears makes an extractor that doesn't require a pilot hole. You just sort of jam this bit into the messed up head and turn it counterclockwise.
Of course, both these methods will mess up the head and you'll need a new bolt.
Perhaps can you jam something into the head, like a screwdriver and use a wrench to grasp the screwdriver shaft and turn?
thanks for the info, both of these methods seem like they would work. i just don't want to mess up anything other than the clamp and bolt. thanks again.
Shimano Certified
While I would reccomend the extractors, if you have access to a Dremel Moto tool, the cutoff wheel fits nicely between the clamp faces to get the bolt. This is the fastest method out of the choices, but you do have to have a steady enough hand to not let it skip.
Quoted: 1572 Post(s)
Liked 643 Times
thanks for all the advice, i appreciate it. its a brand new frame, spicer track, and i really DONT want to mess anything up. thanks again.
