Coaster brake on a chromoly frame.
Bikes: Giant TCRC2 2007, Dahon MU P8 2012, GT Avalance 2011
Quoted: 8 Post(s)
Could I put a coaster brake on a chromoly frame without damage to the chain stays? I'm looking to make my bike a 3 speed IGH and was wondering about this. I'll be heading to my LBS next week to look for wheels and wanted some input before I go.
Thanks
Thanks
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12637 Post(s)
Liked 7,529 Times
What kind of cromo frame. I think all but the lightest, raciest 3% of cromo road frames could take it. Probably only about 0.125% of cromo MTB frames might have troubles with it.
Just put a snippet of innertube under the strap to keep the frame pretty.
I'd probably just get a non-coaster 3-speed, though. Actually I'd probably get that Sturmey Archer 3-speed Fixed hub, but that's just me. You can roll it fixed or screw a freewheel on it.
Saving gas on my commute
Quoted: 8 Post(s)
It's an older 1988 Mtn bike frame, Giant Sedona, I want to use it on my 11 mile RT commute. The thought behind the coaster brake was just to get some stuff off the handle bar. Maybe duo drive hub would work where you kick back to switch gears but I'm not very familiar with those.
One thing to keep in mind with a coaster brake is that it can make getting your pedals in position at a stoplight a little tricky. Some people are bothered by this, others figure out how to make it work.
bike whisperer
Quoted: 1520 Post(s)
Liked 716 Times
Hands up if you've ever just bent the arm out to hit the bottom of the chainstay cause you don't have a strap
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Bikes: everywhere
Liked 7,529 Times
:hand raised:
Because of recent work I've been doing I've been considering some of the cone wrenches at the bottom of this page:
https://www.greenephantom.com/books_and_catalogs
I figured out a way to "rig" the bearing setting the other day but it would be so much easier with these in the future.
Quoted: 86 Post(s)
i've run single speed (SA) coaster brakes on a number of my 80's vintage lugged steel frames without trouble. and there was a time when i ran a seven speed Nexus with coaster brake on a custom bike with Reynolds 753 rear triangle. again, no problem.
There are straps like I got with my Drum brake hubs with 2 bolt holes.
1 bolt holds on the strap, to the frame, for the 2nd, I substituted a pin with a ball catch ..
I made puncture repairs simpler.. just needed the axle bolt wrench..
Definitely no problem putting a coaster on a cromoly mtn frame. HOWEVER, the axle length (OLD) on most coaster hubs is narrower than a mtn frame. You'll need to respace the hub's axle (good) or coldset the frame (not so good)
Bikes: CCM Torino 76
I wouldn't worry about the stress the strap will put on the frame - it can handle it. However, does the 1988 Giant Sedona have horizontal or vertical dropouts? Later versions definitely had vertical dropouts, which makes them unsuitable for coaster brakes. If your older model has horizontal dropouts then it will work fine.
jimn
Bicycle Mechanics
19
10-01-16 05:55 AM
Deathly Hallows
Classic & Vintage
2
10-15-11 12:01 PM
Fairmont
Bicycle Mechanics
6
05-24-11 09:28 AM
