Million $$ Idea: Stairway Carry Handle
I can't believe when I googled "bicycle accessory stairway carrying handle" all I got that was close was a post on this forum by "white_feather" in 2008. Com'on all you shop mechanics, don't you want a patent. Just give me something I can bolt to the bottle cage mount I don't use, to carry my bike down the stairway at my condo. I'll gladly pay $50 for something light weight and maybe foldable or detatchable. I'm trying to adapt an AutoTecknic Carbon Fiber E-Brake Handle to modified Bontrager bottle cage, but I just don't have the time or resources. This is an accessory whos' time is overdue. Thanks to anyone listening.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
While a carry handle sounds like a plausible idea on the surface, it would end up being a fiddly-bit that someone in a hurry would just ignore in favor of grabbing the bike by the frame tubes.
Friendship is Magic
Bikes: old ones
Quoted: 26251 Post(s)
Liked 10,232 Times
Here's a tip: always aim the front wheel down the stairs
Here's another tip: always hold the bike underneath the tip of the saddle
For going down stairs
1. roll bike toward stairs
2. place hand under tip of saddle
3. lift up bike, notice how front wheel dangles downwards, closely matching angle of stairs
4. walk down stairs
For going up stairs
2. flip bike around to rear-wheel points towards stairs, front-wheel points away from stairs
3. place hand under tip of saddle
4. lift up bike, notice how front wheel dangles downwards, closely matching angle of stairs
5. walk up stairs
4. walk down stairs
For going up stairs
5. walk up stairs
Bikes: lowracer, highracer, moving bottom bracket, 2 tall bikesl
Quoted: 184 Post(s)
Liked 67 Times
Handle: https://www.copenhagenize.com/2011/03...-cyclists.html
Shoulder Strap: https://gajitz.com/stepping-it-up-sho...es-up-stairs/?
Portage Strap : https://www.etsy.com/listing/57492833/bike-portage-strap
Bikes: '74 Schwinn Le Tour (x2), '83 Bianchi, '96 Trek 820, '96 Trek 470, '99 Xmart Squishy Bike, '03 Giant Cypress
Looks like some first-year design student needs to go back to the drawing board...
4. walk down stairs
For going up stairs
5. walk up stairs
4. walk down stairs
For going up stairs
5. walk up stairs
carry the bike from the non-drive side.
Carry the bike so it is on the inside of turns.
Friendship is Magic
Bikes: old ones
Liked 10,232 Times
There.........saved you fifty bucks......you're welcome.
Shoulder bike, reach around head tube, to grasp handlebar left side,
this raises the front wheel higher, so you can climb or run up stairs.
might leave the rear tire's marks on stairwell walls..
NB, Bottle cage bosses , particularly the Riv-nuts in carbon Tubes.
may not be durable in the use you desire.
Bianchi Goddess
Quoted: 2912 Post(s)
Liked 2,836 Times
Actually I believe at one time some bikes, maybe Dutch city bikes, had handles. Bianchi actually had brazeons on thier cross bikes in the late '80s early '90s for a nylon web strap.
Sugar "Kane" Kowalczyk
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
collector
I had a portage strap made of nylon and padded like a backpack, it worked pretty well if you pointed the front wheel down the stairs. Those leather ones posted above look interesting, they also offer a spot to lean the bike against things so it doesn't scratch the paint.
bike whisperer
Quoted: 1520 Post(s)
Liked 716 Times
Holding my bike like this works just fine for me.
It's how the cyclocross guys do it, innit?
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Si Senior
Bikes: Too Numerous (not)
Quoted: 23 Post(s)
Liked 10 Times
I love that leather portage strap. Also don't heft bike on left shoulder with front wheel forward, or right shoulder with rear wheel forward. You'll get chain muck and grease all over your nice shirt/jacket (been there, done that).
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
If I acquired a bike with a carrying handle I would remove it. Much rather replace it with another bottle holder or with nothing.
Don in Austin
Thank-you my cycling brethren for all your helpful tips and ideas. Maybe it's time for this old rider to find a first floor unit.
Newer Brompton saddles now include handle like grip under the nose.
to pick the bike up by when folded.
Places that have bikes as common transportation,
put a ramp in the stairs to roll the bike up as you climb the stairs.
or there is the bike escalator , as in Trondheim Norway..
https://www.youtube.com/watch?v=ryCWIjdVF0g
Add I do remember a bent tube welded on the frame at the bottom,
joining the down and seat tubes.. a handle of sorts..
and another design making a curved shape at the top
where seat and top tube joined.
they were different bikes.
and the additional pieces were in steel, part of the metalwork,
before the paint went on.
The main problem of inefficient technique is that you waste so much energy fighting the bike. My wife absolutely hated cycling when we met becaused she lived on 2nd story. The problem with going up stairs front-wheel first is you're fighting physics:
1. center-of-gravity of bike is mostly towards rear-end
2. front-wheel will flop back & forth if front-end is aimed upwards
You end up with ungainly situations like this:
Lifting a bike 3-4 ft into the air just so that you can aim the front-wheel down and control it is tiring! Especially after a long ride and you barely have enough strength to lift your own body weight up. Once I taught her how to lift the bike just 6" to go up stairs by aiming the back wheel first and lifting by the nose of the saddle, it was so easy that cycling was fun again. She could even bring her bike up stairwells that were only 2-feet wide without trouble.
bike whisperer
Liked 716 Times
YMMV with a bigger gap between downtube and front wheel, or a compact frame.
