Nonleaking insulated water bottle?
On my Cannondale RT2 the 2 bottles that are more horizontal always leak. I've tried Polar bottles and Camelbak Podium Big Chills; both leak during a ride. The latter do not leak before a ride, so I assume it is bumps that cause it to leak. Even tried brand new ones - never run through dishwasher - same thing. Problem is I use Gatorade in those bottles (Camelbak backpack for water) and the leaking causes a big sticky mess by the end of the ride. Is there a bottle anyone has that does not leak?
Carpe Velo
Bikes: 2000 Bianchi Veloce, '88 Schwinn Prologue, '90 Bianchi Volpe,'94 Yokota Grizzly Peak, Yokota Enterprise, '16 Diamondback Haanjo, '91 Bianchi Boardwalk, Ellsworth cruiser
Liked 14 Times
I've had polar bottles leak as well. I need to find a Celeste colored sports drink.
Bikes: Custom 650B tandem by Bob Brown, 650B tandem converted from Santana Arriva, Santana Noventa, Boulder Bicycle 700C, Gunnar Sport
Quoted: 23 Post(s)
Bikes: Volagi, daVinci Joint Venture
Just for grins try a few turns of teflon (plumber's) tape around the threads before putting the cap on. Won't take but a few seconds and can't hurt to try. Part of the problem may be expansion of the liquid as it warms up; might be hard to defeat that additional pressure.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
As a test, I filled my Camelbak Podium and Ice bottles, and turned the valve to the Lock position.
First, a hard shake. Nothing leaked.
Next, a hard squeeze. They leaked around the threads when I had the tops tightened as usual. If I tightened them a little more, even a squeeze didn't leak.
(Turning the valve to Unlock, they will leak out the nozzle when shaken. But that doesn't sound like your problem.)
But other BF comments have also complained about leaks. I wondered if they had tightened the caps too much, distorting the cap, so it wouldn't seal correctly any more.
The threads don't seal the bottle. Only the lip at the top of the bottle seals against a ridge in the cap. So teflon wouldn't help. That sounded like a good idea, until I looked at my bottle.
A rubber ring that fit in the cap would work. But it would have to be the right size.
Expansion of the contents
I've had my Podium bottle in the car (unlocked) when driving up a mountain. The lower air pressure makes the silicon valve whistle as air goes out of the bottle. But that's a lot less pressure difference than squeezing the bottle, which doesn't leak for me. And the water wouldn't expand enough to make a difference as it warms up.
Trail Blazing
Bikes: Specialized Roubaix, Specialized Epic, Niner RLT 9 Steel, Cannondale RT2 Tandem
I use the Camelbak Podiums and never have leaks. But perhaps I get the lids a little too tight.
I have used Polar and Camelback and they all leak and it gets worse as they age.
I am now trying Specialized Purist and it seems to be better but not sure if it leaks or not.
It isn't insulated but I am ready to give up on that.
Hey check out www.dryjug.com it might be something worth checking out.
Oldie. Boy, howdy!
Bikes: 2005 Trek T2000 tandem, Giant TCR, Eddie Merckx Majestic Ti, Fuji Team, Giant Revel 29er, Windsor Clockwork (Orange) fixie, and a BikTrix Juggernaut Ultra 1000 fat tire eBike
BICYCLE - [[I]bahy-si-kuhl] - Noun :> A medical device used to correct the common geriatric condition of OFS, (Old, Fat & Slow), in a manner that does not induce brain-decaying boredom like walking or running.
Oldie. Boy, howdy!
A Google search for "o-ring" returned a host of companies that sell a myriad of o-rings in various sizes and materials. May be worth a shot.
Quoted: 77 Post(s)
Liked 19 Times
Seriously . . .
You can mount bottle cages in a more upright position like on the handelbars and tri-style behind the stoker's saddle.
Facanh
10
08-25-18 03:01 PM
volosong
Fifty Plus (50+)
47
03-25-12 08:28 PM
