Larger Grips?
Bikes: Giant Talon 1 29er
Larger Grips?
I am 6'2" 300lbs so I put a lot of pressure on my hands and elbows while riding. I am looking for some larger or thicker grips to accommodate my large hands and help to alleviate numb hands and sore elbows.
https://www.rei.com/product/722554/ergon-gp1-grips-large
Also the handlebar maybe a bit far from reach? If so, get a adjustable stem or move the saddle closer. Only enough to still feel comfortable. What kind of bike is it?
Also you can always swap your handlebar to a butterfly trekking handlebar.
https://www.google.com/products/catal...ed=0CG8Q8wIwAA
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
You should have your fit checked out as well. There shouldn't be a lot of weight on your hands, no matter how much you weigh.
I'll go along with both answers. I use the small Ergons, and there is lots more contact area than with the standard grips. The large size is reported to be really large. I do notice that other companies are borrowing the concept.
Don't ignore the fit comment.
Some people are like a Slinky ... not really good for anything, but you still can't help but smile when you shove them down the stairs.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Takes time, but I had to learn to relax my grip and arms while riding.
Fred "The Real Fred"
Try a double wrap of road bar tape, works for me.
What everybody else said--but I think there's a good chance this is a fit or setup issue, and grips aren't going to fix it. I understand being reluctant to pay for a pro fitting, but at least google it and figure out what you need to change to shift weight off your hands.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
ergon grips
SIT MORE UPRIGHT TO GET YOUR WEIGHT OFF OF YOUR HANDS WRIST AND ARMS.
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Quoted: 37 Post(s)
It is impossible to tell you what you need to do without actually knowing or seeing you on the bike. But in general all the above are things to think about that may help but also they are like shots in the dark at your problem with the exception of getting properly fitted as a starting point. It is also possible to do your own fitting with some understanding of the process and also knowing your own abilities. The self-fitting with some understanding of what you want to accomplish is ok but you can see from just a few posts everyone has different ideas about what posture they like. Upright is ok but you will be fighting the wind and on longer rides the pain can move from the support of the hands to the support of the back side. Upright posture also IMO doesn’t involve all the muscle the same as a more aero position will.
The one thing mentioned above I wouldn’t recommend is moving the saddle forward to reduce reach and making a more upright posture I an attempt to take weight off the hands. I have found doing that can actually put more weight on the arms and hands and here is why. The first thing I do when I try and fit myself on a new bike is get the saddle height correct for the amount of leg extension I want. The second thing is to adjust the saddle front to back regardless where the bars fall at. The crank doesn’t move and you need the saddle in the place where when seated you are far enough back that you can have balance using your core muscles reacting against the push of your legs. Much of your upper body weight that’s now on your arms can be held up with your abs and counterbalanced by your butt moving back. For an experiment stand with your heals to a wall and a chair in front of you to use like handlebars start leaning forward to put your hands on the chair. You will want to fall forward because your upper body weight can’t be counterbalanced with your but moving back. Now move out from the wall and try it and its natural to shift the weight back at the same time you bend forward and you won’t even need the chair for support. I try and get that same feeling on the bike. I will attach a photo I found on line that pointed out the posture to me.
As far as padded grips or padding bars I have done both. If you have wrapped bars there are gel pads you can put under the wrap I sometimes use some of the old tape under some areas where I want a little more pad. The grips that have the paddle on them are nice also. Having more than one hand position helps the most and you can get that on some bikes with adding bar ends that will also take a mountain bike grip if you like. Trekking bars also give lots of hand locations and work well. The best tip I have found for numb hands is the spot on the hand that you put the pressure on. It has to do with blood flow and nerves and such. But the pad opposite the thumb pad on the outside of the hand is where I try and put the weight to avoid numbness, that and keeping the wrist angle both ways about in the middle of the range of motion. Straight bars for me are the worst and I know many like riding them and have no problems.
If you get your saddle height and position correct and you are faced with the wrong reach you have to then fix that with stem and bars. Likewise bar height is important and that can be fixed with stem and bars. IMHO no one would solve bars to low by lowering the saddle and by the same token you shouldn’t fix reach by moving the saddle forward.
I added some lines to the photo of each rider showing where the shoulders are related to the crank and the stem. You can be the judge of what looks best.
