Quick Fix for Crooked Valve Stem??
Old 01-06-05, 11:58 PM
Drive the Bicycle.
Bikes: Three-speed modified for comfort.
-- OK so say I just replaced the tube and reseated the clincher tire and inflated it. And the valve stem is not perpendicular to the rim. What are the quickest tricks to coax the innertube around without having to unseat the tire again?
77Univega is offline
Old 01-07-05, 01:24 AM
Shimano Certified
mtbikerinpa's Avatar
Bikes: 92 Giant Sedona ATX Custom
Quoted: 38 Post(s)
Liked 6 Times in 5 Posts
Deflate it and grab the tire. Slide it in the direction the valve is leaning.
mtbikerinpa is offline
Old 01-07-05, 01:53 AM
Total Hack
labratmatt's Avatar
Right! This is the only way I know of doing this. You may have to remove one side of the tire. Those tires, even deflated can be pretty stiff.
labratmatt is offline
Old 01-07-05, 03:58 AM
Quoted: 19 Post(s)
Liked 7 Times in 7 Posts
If you use the nut to hold the valve in place when you put the tyre on. You have to back the nut off when you inflate to seat the tube properly.
MichaelW is offline
Old 01-07-05, 09:17 AM
Glutton for Punishment
Quoted: 5 Post(s)
Liked 8 Times in 7 Posts
Not all tubes use a valve stem nut. Also, if you make sure to put some talcum on the tube before reassembly, it'll make straightening that stem much easier.
mswantak is offline
Old 01-07-05, 11:45 AM
Drive the Bicycle.
-- THANK you everyone for your concise answers. (Gotta love this Bike Forum)
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
