need a body shim for a 70s freewheel
No response on C&V so I'll try here.
I have a Maillard Course freewheel from the 70s, in good shape, that never really spun well because the internal bearings were too tight. It seems like it needs another internal 'shim' and I've read that freewheels were occasionally shipped without the optimum number of shims. I don't want to give up on this freewheel, but the right shim is hard to find. In the photo below, the shims are at lower right. I measure inside diameter as 27mm and outside as 30mm.
Quoted: 38 Post(s)
Liked 11 Times
You can try Loose Screws on the net,they might have something.If not,just cut one out of paper,it will be fine.If you want to get all fancy,get some brass shim stock and have at it with the scissors.
try a bikeshop ,they might have a bad freewheel to give away ,which you can use the shims from.
Malliard used to be part of the Fichtel Sachs Group of companies,
before SRAM did a financial take over.. Malliard ARIS freewheels were available ,
parts,
till 90's somewhere
Sram had interest in Sachs producing a rival gripshifting system,
and their internal gear hubs,
but I suppose not in the French Freewheel company.
they have since closed all European production facilities
and are using Taiwan based manufacturing, instead.
parts,
till 90's somewhere
Quoted: 5766 Post(s)
Liked 2,538 Times
Pardon my total ignorance, but I don't get how you can find yourself needing a shim.
The way these work is that might remove a shim if/when the freewheel develops play because of wear. I can't see how one can become tighter.
I used to sell a ton of freehweels, Regina, SunTour, and Maillard. In the 20-30 years selling these, in numbers running into the 10s of thousands, I've never heard of one needing an additional shim.
Sometimes a freewheel might feel a bit tight when new, but that was always from dried oil/grease and quickly resolved with a few drops of fresh oil.
FB
Chain-L site
FB
Chain-L site
ot.net slave
Bikes: Salsa mtb * 3, Intense mtb * 1, Abeni SS rd * 1, Salsa road/touring * 2, Trek Damn one * 1, Vintage/projects * many
The guy says his is too tight, he's probably not lying. As it happens, I have a Suntour which is too tight as well. I also have a super-thin shim that came out of a cheap Shimano freewheel (which was too loose). Let me know if you want it, I'm in Australia.
- Joel
- Joel
Liked 2,538 Times
If you really want a shim you can make a very nice .001" shim with a piece of decent paper. Use an existing shim to trace the pattern with an exacto knife, or the corner of a sharp razor knife. Then soak it in oil and use it. It should be the first one in, against the body, so tightening the cone doesn't tear it. Since it's in pure compression it'll last forever, and the oil will keep it from rotting. If you want something nicer you can use a $1.00 bill, but that's about twice as thick.
FB
Chain-L site
FB
Chain-L site
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
|3iker
Bicycle Mechanics
47
11-29-10 05:43 PM
