Garmin Cadence sensor question
Old 06-15-12, 09:40 AM
I have been riding a hybrid road bike for awhile now and have enjoyed my cadence sensor. Yesturday I purchased a new bike and my hybrid is going to become a dedicated family rider. I have no reason to keep my cadence sensor on there so I would like to switch it to my new bike instead of just purchasing a new one. I am just curious if I will be able to move the magnet from the pedal or if I will have a problem from the adhesive pad?
cmcgarvey is offline
Old 06-15-12, 01:00 PM
a1penguin's Avatar
Quoted: 139 Post(s)
Liked 33 Times in 20 Posts
You should be able to purchase a magnet at LBS/amazon/ebay or elsewhere for a couple of bucks.
a1penguin is offline
Old 06-15-12, 01:08 PM
LeeRoySD's Avatar
You probably won't have any issues but my suggestion would be not to re-use it at all. You can get a small but very strong magnet that is round and flat (looks like a watch battery with about a 1/4'' diameter from any hobby store for a couple bucks. Take one or two of them and stick them them to the end of your pedal axle on the inside of your crank arm. Position your cadence sensor a little farther back on the chain stay than you would if you were using the strap in order to match the new magnet position. This works just as well, looks cleaner, and you never have to worry about bumping the strap with your foot. The magnet should magnetize to your steel pedal spindle, but if it doesn't for some reason, a little glue will keep it there just fine. This, however, usually isn't necessary.
File Type: jpg
File Type: jpg
LeeRoySD is offline
Old 06-15-12, 03:26 PM
Ok, cool, thanks for the responses guys!
Old 06-16-12, 07:35 PM
kenmcchord's Avatar
Bikes: 2006 specialized s-works Tarmac, 2013 Surly Disc Trucker
LeeRoySD,
That is a great idea, nice! I hate the look of my garmin magnet on my pedal crank, plus it seems to move around a bit as I've had more than my share of soaking rides, this might just be the fix.
kenmcchord is offline
Old 06-21-12, 07:00 AM
Hairy Hands's Avatar
Bikes: Colnago C50, Specialized TriCross Carbon
Get a Rare Earth magnet and stick it to you pedal axle. It will never come off. All different sizes available on eBay
Hairy Hands is offline
Old 06-21-12, 10:14 PM
rdtompki's Avatar
Bikes: Volagi, daVinci Joint Venture
Liked 3 Times in 2 Posts
or Ace HW! Sometimes our cadence magnet decides to depart the pedal spindle and attach to the chainstay (steel frame). Only happens once/month or so. Cleanest way to get cadence.
rdtompki is offline
Chris516
11
10-30-14 09:25 PM
ilovecycling
Road Cycling
28
04-11-12 10:31 PM
thedood
Road Cycling
4
01-26-12 09:33 PM
fritxbox
Road Cycling
39
01-06-12 05:41 PM
TP_Mantis
Tandem Cycling
6
09-30-11 01:01 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
