FORK...Help me pick a new shock
Quoted: 413 Post(s)
Liked 109 Times
The OEM Rhock Shox Judy on my Trek 6700 is toast. From reading the sticky and a few older threads I'd like a coil spring fork. What should I get?
Here are the details:
Weight: 190lbs
Bike: Trek 6700 hardtail
Trails: I'm in Florida....cross country...no drops, occasional stairs, a millioin and one tree roots and rocks per ride
Price Range: Under $500 out the door. I'm going to buy a take-off or left over model from a local dealer
So, what do you suggest?
Weight: 190lbs
Withdrawal Symptoms!
Bikes: Specialized Hardrock Sport Disc 2004 And identit Dr Jekyll
Think i'd have the say the Marzocchi MX Comp ETA, very nice forks, and for £209 you cant fault them... Very good for XC, can handle small drops if need be, and will take stairs, they are available in 85 or 105mm...
Weigh in at 1.8kg without the steerer tube so thats pretty respectable for a fork in this price range, if i was spending that money on a fork, i would get the MX, will be a VAST improvement over your Judy
Back to granite
Bikes: '02 C'dale Jekyll 700, '04 C'dale R1000 Double
Fox Float, I believe that is Fox's coil sprung fork. Everyone I've read says mucho plush. I haven't ever ridden one, I ride air sprung stuff right now.
Edit: Check the fork sticky at the top of the forum, it can be found here as well.
a badass heeb on wheels
Bikes: Santa Cruz Chameleon
fox float or F100X. if you have the money, fox should always be your first pick.
Originally Posted by zeddybear
answer axel super- 70-120 mm of travel- RTWD, lockout
hella stuff
hella stuff
I will never recommend an Axel of any sort. Do a search and read the reviews...
Still kicking.
I won't reccomend a Fox, don't like them. You could get a Manitou Black, Marzocchi MX Comp, Rock Shox Duke.
Appreciate the old bikes more than the new.
Campy or bust :p
Bikes: Surly Karate Monkey commuter build
I thought the Vanilla was the coil sprung fork from Fox, not the float. At any rate, I'd say the Rock Shox Reba SL can be had for under $500 and appears to be a nice fork.
