Converted bike, chain falls off
Playing catch up
Bikes: Felt F4
I'm posting this to inquire for my brother. I've personally never have had much experience with single speed bikes and my brother recently got an old peugot 9 speed bike and he took the gears off to make a single speed. He got the fixed wheel rear tire but the geared crankset stayed. The chain stays on fine but after a few mins or riding, it comes off everytime. We've tried tightening the chain, loosening it up but it falls off everytime. He's getting frustrated because he's had it for a few months and can't seem to fix it. Would the solution be to get a single speed crankset or is there something else we can try?
Also, he has the single speed chain he bought as well.
Thanks
Thanks
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Sounds like the front chainring is worn, and the chainline is probably off.
We win all charity rides
Bikes: BMX, fixed gear
My first thought was chainline. Maybe try putting it on a different cog of the cassette?
Bikes: Caad9, Fixed gear, Hardrock beater, 3 speed cruiser
you might be able to get away with getting a bottom bracket that has a spindle length of around 110
If fixing the cabin line doesn't work, look at the chainring and make sure it not bent.
I don't think it's the frame, but it could be some serious flexing taking place. Are you guys sumo wrestlers?
Bikes: Peugot 1980 Road FG Convert
Look up a chart which explains how many spacers you need to align chain. Also pics would help.
Your cog is slipping.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
what cog is he using? A good FG cog is designed so the chain stays on the cog. If you used a cog from a multi-speed cassette, it is designed for you to easily shift gears (not good if you only have one gear).
Check the spindle too -- see if the chainring wobbles left to right at all when you spin the crank. My old bike had a slightly bent spindle, and the chain went from overtight to a bit too slack in each turn of the crank.
Lebowski
Bicycle Mechanics
12
10-20-21 06:07 PM
saturnhr
Bicycle Mechanics
7
06-05-13 03:50 PM
