Trek DS 8.4 - which fenders?
Just got a new Trek DS 8.4 and would like to outfit it with fenders, preferably full fenders. It has disc brakes so that is a consideration. Any suggestions would be appreciated. Thanks.
Bikes: Seven Axiom steel, Salsa Vaya,Specialized Sectuer, Santa Cruz 5010
A new DS 8.3 guy here who's interested in the same thing.
Thanks
Thanks
Bikes: Classic lugged-steel road, touring, shopping, semi-recumbent, gravel
Quoted: 46 Post(s)
Liked 81 Times
Bontrager fenders sold by Trek are really nice. I just installed these a week ago on my city bike. Of course I had to do some major rigging to get them to fit properly on my '80's-era Panasonic.
Bikes: Trek DS 8.3
I had SKS chrome plastic fenders on my 8.3, but just moved them to a 7100 as it is taking over my commuting duties. The back was a little tricky, but they attached to a mount point above and behind the brake caliper, and once adjusted didn't cause it issues as the stays bowed out enough.
The front one required some help. The way I found to do it, and had it confirmed at the LBS when I asked them how they would do it and they showed me, was to share the top mounting bolt with the caliper. This requires a longer bolt, and a standoff (or a lot of washers) so that the stay are positioned out of the way of the arm that actuates the brakes. Also none of the included bolts fit the mount point in the bridge of the front shock/fork.
The 8.3 has mechanical brakes, the 8.4 has hydraulic doesn't it? The fit probably will be different for those.
When I had them on they worked great. I've decided to treat my 8.3 more as a "sport bike" for longer/faster road rides, and off road stuff now that I have the 7100 to handle the commute and family rides, so I'm eventually going to go for some of the "sporty" smaller fenders on the 8.3 that clip on and don't have stays, but it will probably be fall before I seriously look into them.
Good luck!
Good luck!
Thanks for the info, Shawn. Yes, the 8.4 has hydraulic brakes. It looks like I might be spending quite a bit of time on adjustments, but as long as they work in the end I don't mind. I'll talk to the LBS and see what they have.
FlashBazbo
Hybrid Bicycles
2
03-19-11 07:09 PM
