Heat is not the problem, Humidity is.
So I started riding last month while I was down in Arizona visiting family and friends. Started off horrible only able to ride two miles or so but got up to 10 or so before I left to come back home to Texas, thinking that because the heat is about the same I could likely ride about what I could before I started off on monday as if it wasn't a big deal, about four miles in I'm already dead. The humidity here is horrible, and my usual trick of using a wet bandana does nothing. Any tips on dealing with the heat while it is 50%+ humidity at all times?
It's the combination of heat and humidity. Would it be possible to ride at night or the very early morning? In any case, you DO get used to it. Just as there was a ramp-up of your capabilities in Arizona, there'll be a ramp up in Texas.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,243 Times
The Only way that I can ride in it, is to pour Ice water on my head and neck about every 20 minutes.
Fred "The Real Fred"
Bikes: 2012 Surly LHT, 1995 GT Outpost Trail
Humidity is more dangerous than one would initially think.
The body cools itself by sweating, and then the act of the air evaporating the sweat cools you down. Unfortunately in humid air, since the air is so full of moisture already, sweat evaporates more slowly, and if the humidity is high enough, not at all.
So on a really humid day, you could be perfectly hydrated and still dangerously overheat because sweating just doesn't work right in high humidity. So, be careful out there, and dial it down when it's high.
I'll start taking a camelback and a bottle of ice water then, that way I can use it to keep cooler by doing the same 10 Wheels, thanks!
I live in Houston, under the great gulf humidity bubble. You think Waco is bad? Try Houston.
I am a 40 mile round trip commuter.
The mornings are worse because there is no evaporation. My evening ride is a considerably more pleasant, and that's mid-90's (F) currently. It'll stay there until September.
I carry two bandanas. For the trip home I start out wearing one. I change that one out about halfway into my commute. Take off the wet one, wring it out, tie it to the handlebar, put the new one on, continue on my way. The first one is dry by the time I get home.
There's not much that I know you can do to combat it but keep yourself hydrated and keep on pushing.
Quoted: 18883 Post(s)
Liked 10,646 Times
It's unseasonably warm and sunny right now, and we're dealing with 68 degrees F.
Granted it doesn't get as hot around here (95-100F) but it is very humid. Favoring the early/late hours for rides is the best option, but even begining early, it'll get toasty towards the end of the ride. Sun sleeves and a tank top base layer helped a lot dealing with heat/humidity here. Soaks up sweat away from the skin but keeps the moisture layer that cools off with air there. Noticeable difference IMO.
Proper hydration becomes even more important when humidity increases.
The term "relative humidity" is a measure of the "absolute humidity" (measured in milligrams water vapor/meter^3) divided by the absolute humidity at its fully saturated state at the current temperature and barometric pressure. It is measured using a device called a wet bulb thermometer. This thing is actually two thermometers. One has a dry bulb, the other has the bulb wrapped in gauze that is soaked in water. They are spun through the air for several seconds, then the two temperatures are read. At low humidity water evaporates off the wet bulb rapidly and the temperature difference to the dry bulb is large. At high humidity, there is little evaporation, because the air is too saturated to absorb more water, and the temperature difference is small.
Thanks for all the advice and info. I'm going to try and rearrange my schedule so I have more time to ride when it isn't the hottest part of the day, just have to hope I'm convincing enough as I really do need to stick with this.
Like WA, Pacific NW OR coast, summer the grey daylight is longer ,
winter high , becomes the summer Low.. 80 is a scorcher..
rain gear always in the pannier.
Yep, I do 40 miles p/day.
20 In. 20 Out.
I live up around Little York & I-45, and I ride over to Westheimer & Kirkwood area. Mostly I'm on residential roads going through the Spring Branch area north of I-10.
It's really not as bad as one would think. You know Houston is flat as a table. The heat is the hardest part of it. Sometimes I just have to grit my teeth and keep sweating.
Thank you, sir.
20 In. 20 Out.
Thank you, sir.
Quoted: 32 Post(s)
just keep hydrated really. Use a camelback if needed and put ice cubes in there. Yes it might be a little heavier but to be frank, it will do the hydration trick too!
If you start showing symptoms, applying cool water directly to the skin will work. 7-Eleven stores here in CA are now putting hand washing sinks at the coffee bars, and I suspect they may be doing it nationwide.
Bikes: Cannondale Quick 4
+1 on the icecubes,
I fill my 24oz bottles halfway the night before I will be riding and freeze them and top them off just before I leave. The 1st one will be partly slushy when starting to drink it, the second one fully melted but still nice and cold.
edit: should have read all the posts, I pretty much copied Commando's but hey, it works great.
I live in north central Florida so I feel your pain. I've found that riding early morning or at night is the best. Since you cant do that just take a ton of water. I rarely leave the house with under 70 ounces of water. I have a Hydrapak Big Sur that holds between 70 to 100 ounces of water depending on how the bladder is set up. I also have 2 cages on my bike that hold the 21 (I think) ounce insulated Camelbak bottles. There's been more than a few rides where I carry my full capacity of 142 ounces of water depending on the ride, heat, and humidity. Dont push your pace to hard either. Take a stop if its needed.
One day I rode 52 miles of rail trail and residential streets and didnt finish all of my water, but it was overcast and lightly raining so I stayed cool. Sunday this week I did a 28 mile ride after tropical storm Debby (dumped a foot of rain on us) which was mostly mountain bike trails at 1 in the afternoon. I had to take a detour to refill my water. The heat and humidity from all of that rain cooking off in the afternoon was insane.
That mountain bike ride was BRUTAL compared to the rail trail ride.
I can't ride well in the heat. I feel like I'm suffering too much. The last two rides I did were the first two that I actually went slower than previous rides. I just couldn't maintain the pace on the hard parts because I hated the heat so much.
Bicycle Commuter
These posts have been useful for me - tomorrow is my first commute in 100 degree heat. I will take plenty of water and go easy when needed. Thanks for the helpful tips.
Bikes: Trek 4300
I know when it gets really hot here, i add 15-20 mins to my trip. Then there is this spot about half way i get off my bike sit down on the grass in the shade and ***** about the heat to my self and the bike .
It takes longer, but some days it is so hot you just need a break.
Bikes: 2006 Specialized Ruby Pro aka "Rhubarb" / and a backup road bike
Quoted: 7 Post(s)
Liked 13 Times
On hot days a camelbak full of icecubes and cold water will help block the sun on my back with something wet and cool. I got an insulated cover for the drinking hose so I don't have tepid water or have to waste the water that heats up in the tube between sips.
Humidity just kills me. I was just wilting on an early ride, temps in mid 80s but no breeze and high humidity. As it got hotter out, the humidity burned off and finally got a bit of a breeze. It really perked me up.
If you can avoid riding with the sun overhead it will help.
I am delaying my evening rides to start after 7pm if possible. Sunset is around 8:30 so I do need to bring lights.
I am easing off the pace, my heart will get enough work just trying to keep me from overheating.
Bikes: Two LeMond Buenos Aires...steel.
Ride very early in the morning and get acclimated to it a little at a time. Never, ever get dehydrated! I rode in 105 degree heat today. As long as you keep moving, it's manageable. Stop and you wonder what the heck you're doing out there..... ; )
I know it's been a long time, but an update is I never fully adjusted to it and still struggle with the humidity during the summer time. I've lost a good 40 pounds over the year or so and am still biking, I bike about 50-60 miles a week every week and am actually intending to ride my bike everywhere I go from here on out as everything I want is pretty much within about 10 miles.
