Smaller crank arms for cross
Old 07-07-12 | 11:56 AM
I was about to pull the trigger on new 175mm cranks; But am now considering going w/ smaller cranks 172.5 after reading this: https://sheldonbrown.com/cranks.html
Looking at OEM cross bikes, it seems that the cranks are 2.5mm shorter than road bike equals. Is this for toe clearancein the turns, or for easier spinning up hills.
What is the general consensus?
Erik_A is offline
Reply
Old 07-07-12 | 12:22 PM
Do the shorter CX cranks feel weird coming from longer on a road bike? I am 6'-4" tall, and until now never considered shorter cranks.
CX = higher BB for clearance + shorter cranks for spin
Erik_A is offline
Reply
Old 07-07-12 | 12:38 PM
What is your inseam? My initial thought is at 6'4" you are going to want 175s. I am 6'1" with a 34" inseam and went from 172.5s to 175s. It doesn't make a big difference but longer cranks give you more leverage for steep climbs and technical terrain.
You will gain a little clearance with the shorter cranks but ultimately bb position will dictate pedal strike and toe overlap. I've got no problems spinning 175s and 180s (100rpm average according to my garmin) and my legs are likely shooter than yours.
thirdgenbird is offline
Reply
Old 07-07-12 | 03:20 PM
Cynikal's Avatar
Titanium Club Membership
20 Anniversary
Bikes: Too Many
Most modern CX frames don't have a high BB like older CX frames. Clipless pedals made it unnecessary. Granted the larger tires will raise up the whole bike a bit. I'd just stick to what you ride on the road or can get a good deal on.
Your frame is BB30 right? Are you using an adapter to get shimano cranks in there?
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
Reply
Old 07-07-12 | 03:32 PM
CliftonGK1's Avatar
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
I'm 6'6" with a 36" inseam and I ride 175mm on my distance, commuter, brevet, and mountain bikes. I put a 172.5mm crank on my CX bike this year, swapping out from the 175mm I had last year.
If I was blindfolded and told to pedal one, then the other, I don't think I could tell you the difference.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
CliftonGK1 is offline
Reply
Old 07-07-12 | 03:46 PM
Yes, FSA BB30 to 68mm threaded adapter.
Erik_A is offline
Reply
Old 07-07-12 | 03:47 PM
My inseam is 35"
Erik_A is offline
Reply
Old 07-07-12 | 03:55 PM
Cynikal's Avatar
20 Anniversary
Bikes: Too Many
If you are buying a new crank, why not get a BB30 crank?
Cynikal is offline
Reply
friday1970
53
12-17-21 03:19 PM
catgita
Fitting Your Bike
27
08-07-17 10:20 PM
Sito
Fitting Your Bike
7
08-10-16 11:50 AM
mtnbke
Classic & Vintage
10
05-05-11 06:43 AM
bigfred
19
01-16-10 01:48 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
