Bike doesnt turn much on the left and turns dramatically on the right
Hi i only realised in the last few weeks that the front turning/rotation so different on the right and left. Is this normal? I don't know why it has taken me so long to see this or is there something i don't know about folding bikes?
Quoted: 321 Post(s)
Liked 7 Times
The only thing I can think of is that the handlebars got twisted around by 360deg, wrapping the cables around the steering column, preventing rotation in one direction as they tighten up.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
What kind of bike and head set? I have had a headset where the lower cup was binding when turned to one side and not the other, turned out the cup was in a bit crooked and the piece on the fork was off the other way.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
https://www.blindfreddyebikes.com.au/page4.php
Its the first bike on this page. I have a lithium battery set up though...upgraded some time ago
Bikes: Brompton H6L-X, Dahon Curve D3
Quoted: 56 Post(s)
-HANK RYAN-
Norman, Oklahoma USA
thanks but this happens wether the basket is on or not. I only just put it on. Its just put on with cable ties as i don't have the proper mount stuff to put it on the right way. i can tell thats not the issue. I should make a video but not now as it is super late in the morning in australia and i need some sleep soon :0)
thanks i am on a pension and can't afford that but when i get a chance will go to a community Bike Club...don't know when that will be though :0)
Quoted: 70 Post(s)
Liked 15 Times
Is it when the bike is under power or just pedaling? If under power it is called torque steer. If not under power, possibly a wheel/fork misalignment.
Aaron
Aaron
Vello Kombi, baby
Bikes: 1973 Eisentraut; 1970s Richard Sachs; 1978 Alfio Bonnano; 1967 Peugeot PX10
Quoted: 80 Post(s)
Liked 14 Times
Could also be the headtube facing/headset installation. Eliminate the simplier to fix stuff first; this one is a bit of a pain. Do check the cable runs. I've seen what jur suggests occur.
"It's always darkest right before it goes completely black"
Waste your money! Buy my comic book!
Its an ebike and i can ride without the motor or both. The motor and battery are on the back of the bike. I am going to the sydney Bike Club in two days :0)
Yeah no its nothing to do with cables. Hard for me to explain but i know its not that.
Quoted: 321 Post(s)
Liked 7 Times
There are just a few things that could limit rotation... the external ones such as a reflector hitting somewhere because it is misaligned, would be easy to spot by careful inspection while turning the steering in the direction in which it binds.
If it binds with a clunk, it is likely to be something that hits against something else (like the reflector). If it just gets gradually more difficult, then I would call the bearing, assuming cables have been eliminated as a reason.
Eliminating all external possibilities, basically leaves only the headset bearings. That is a bike shop job if you lack the tools and know-how.
Good news the handy neighbour turned up and it was that thing that is where the bike rotates that needed adjustment. Sorry not good at explaining and it did seem obvious but i am not very strong due to illness. I also thought the tool i have was not big enough to do the job...anyway its good news and i can go around corners now better than ever. Even my neighbour that has a talent for fixing cars didn't know why this occurs
Bikes: Wheeler Mtn bike, Strida 5.0, Tern Link Uno, FSIR Spin 2.0, Dahon Mu P8
Quoted: 34 Post(s)
Glad you got everything fixed and in working order. But that's very weird that the headset can bind in such a way. Also since you are riding a pretty expensive E-bike and it's probably your main form of transportation, I would fold it up and bring it in with you whenever you can!
Yeah he unscrewed whatever the thing is and then turned it? then re tightened? Sorry both he and i didn't get why that worked. One of those puzzling things i guess
Quoted: 321 Post(s)
Liked 7 Times
So it is the headset bearing. Sounds like the lock nut on top is/was not locked and the adjustment tightens up when turning to the right. That should not happen... something may be adrift.
Quoted: 9 Post(s)
Was thinking along the same lines. My guess was that the lock washer was missing between the lock nut and bearing cap(or whatever the technical term is). Turn it one way, tightens bearing. Turn it the other, loosens bearing. The lock washer is usually keyed to keep it from turning. If this is the case, I'd go over the entire bike with a fine tooth comb.
Oh ok not sure what you mean as i just don't know enough about modern bikes. The bike has been in the shop many times since i have had it so maybe they didn't look at everything during its multiple stays! Ah well will see how i go with Bike Club tomorrow not that i think anyone there knows that much about this type of bike...its useful what you said though as i will push whoever i can get a hold of to look at everything.
Quoted: 9 Post(s)
The Spacer between the Locknut and Threaded Top Race is keyed to a slot in the Steerer, preventing the locknut from tightening the top race. The keyed spacer may be missing from your bike, or was possibly replaced with a plain washer.
ok i get what you mean. will check this out tomorrow as the bike is locked away and time for bed :0) thanks so much
Threaded headset adjustments require 2 wrenches,
The one that fits the adjustable top race, is thinner .
often 1/8" thick and a 36mm..
if stem is 1",
regular bikes usually 32mm .. stem is 7/8"[22.2mm]
if stem is 1",
Thanks for the info. Will log into this forum when i get to bike club so they will know what to do or this will help them anyway if there is doubt :0)
Vello Kombi, baby
Quoted: 80 Post(s)
Liked 14 Times
Indeed. Stand over the bike and hold down the front brake. Shove the bike back and forth ; if you feel a click your headset is now too loose. It was certainly too tight at points in the rotation.
