Chainring wear. Is it time for me to replace all this?
Old 07-09-12 | 02:39 PM
David Bierbaum's Avatar
Bikes: 1992 Specialized Crossroads (red)
I just noticed today, while cleaning gunk out of the cassette and chainring, that my chainring seems to be displaying the classic look of the worn chain and/or chainring. Excuse the blurry photo. I'm not used to my new camera just yet.
My cassette doesn't look so bad, but I spend most of my biking life in that middle chainring. About how bad can one of these get, before one needs to change?
File Type: jpg
David Bierbaum is offline
Reply
Old 07-09-12 | 02:50 PM
Mechanic/Tourist
Bikes: 2008 Novara Randonee - love it. Previous bikes:Motobecane Mirage, 1972 Moto Grand Jubilee (my fave), Jackson Rake 16, 1983 C'dale ST500.
Depends on what you define as needs to change. Grinding when pedaling, even on a clean chain and especially on a new one is a pretty good indicator, may not shift as well, and the teeth usually become pointed. It will "work" pretty much indefinitely, but will be much more pleasant when you replace it.
One usually checks at the front of the chainwheel rather than the bottom.
cny-bikeman is offline
Reply
Old 07-09-12 | 04:01 PM
ThermionicScott's Avatar
10 Anniversary
How long has it been since Shimano stopped making Ultraglide chains? Probably time to replace it!
ThermionicScott is offline
Reply
Old 07-09-12 | 04:45 PM
bikeman715's Avatar
Bikes: Bike Nashbar AL-1 ,Raligh M50 , Schwinn Traveler , and others
shimano still makes UG chains . some new low end bikes in the shop still use them .
bikeman715 is offline
Reply
Old 07-09-12 | 06:34 PM
dddd's Avatar
Ride, Wrench, Swap, Race
15 Anniversary
It would be much easier for folks here to discern tooth wear if the photo shows just the teeth in profile.
Severe wear can result in slippage under maximum load, which is dangerous.
Likely the chain is somewhat worn, and should be precisely measured pin-to-pin over a 12" length.
Anything over 1/16" per foot (0.5%) is considered worn out by today's standards, and I concur.
dddd is offline
Reply
Old 07-09-12 | 08:55 PM
dsbrantjr's Avatar
15 Anniversary
How many cassettes have you gone through? A set of chain rings should last through several cassettes unless you let the chains become severely worn. I suggest that you measure the chain as suggested above and replace it if it is worn. Cassettes and chanrings should be replaced on condition not by inspection; if they do not skip with the new chain all is good.
dsbrantjr is offline
Reply
Old 07-09-12 | 09:26 PM
Titanium Club Membership
15 Anniversary
You can ride a chainring until it's pretty badly worn with little or no problems. If the chain is running OK, and doesn't slip under power then you're still OK. I check for chainring ear as follows. Use a small screwdriver to lift the chain away from the chainring at the front (half way around the wrap). If you can see 1/4" of daylight under the chain the ring is pretty worn, but I have one ring where I can pull the chain almost 1/2" off and it still doesn't slip, (but it does creak under load).
FB
Chain-L site
FBinNY is offline
Reply
Old 07-09-12 | 10:37 PM
The trekking bar and the rack on my bike are the only new parts. All the components are original to the bike when I bought it new... in 1992.
I've already blown my budget for this year, so unless things get noticeable, I'll just leave things be for now. There seem to be two camps with regard to change. The change chain, and you should change the sprockets camp, and the change the chain, but leave the rest unless there are problems camp.
Edit: I measured my chain, and it has no wear at all! 12 inches, 12 links, perfect match, relaxed or under tension. The wear is all in the ring, it seems.
Reply
Old 07-10-12 | 04:33 PM
dddd's Avatar
15 Anniversary
Enjoy your new bike!
dddd is offline
Reply
CycleryNorth81
Classic & Vintage
13
05-16-19 09:01 PM
Doctor Morbius
Bicycle Mechanics
19
10-08-17 08:50 PM
dimethi
Bicycle Mechanics
11
06-27-16 04:52 PM
asmac
Bicycle Mechanics
17
07-16-14 02:49 PM
brundle_fly
Bicycle Mechanics
19
12-09-11 06:47 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
