Installing a cartridge bottom bracket without specialized tools?
Hi guys, I'm new here. I don't know if this has been asked or not, but are there any DIY cartridge bottom bracket tools (like there are headset cup installation tools?) My LBS owner is sort of a prick about letting people use his parts and I want to do it myself, as I'm a novice still learning. its a 68mm bottom bracket, if that makes any difference. Thanks!
Quoted: 550 Post(s)
Liked 325 Times
Different threaded bottom brackets take different tools. Campagnolo uses a cassette tool for many of their traditional bottom brackets while Shimano did it's own thing. ISIS bottom brackets take a different tool. Most of the external bearing models seem to share the same 16 spline tool. Just get the special tool.
While press-fit bottom brackets (BB30, BB90, etc.) can be installed using a headset press it's possible to use a mallet and block of wood to spread the load.
Quoted: 2026 Post(s)
Liked 1,096 Times
Mechanic/Tourist
Maybe the owner is less than gracious about his decision, but it's perfectly understandable. I was service manager at a bike co-op where we had free clinics so people could work on their own bikes. Not every shop can do that, but even we did not give people access to the mechanic's area or to specialized tools.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
I know what it is like to be on a very tight budget but if the choice is between paying the LBS $15 to do it for me or buying a tool for $10 to do it myself, it's a no brainer.
Bikes: Bosomworth '84, Morrison Pursuit, Tarini Prima & Firenza, Miyata 710 '86, Fuji Finest '82?
Just use your teeth.
If you don't have money, cultivate friendships with tool-owning amateurs. Not your LBS owner, he is not an amateur and you need to preserve your goodwill credits with him for when you really get stuck.
There's a lot of specialty tools you need when working on bikes. Suck it up and buy the tools like the rest of us did. You'll save money in the end and learn the satisfaction of doing it yourself.
And bad on you for thinking that the LBS owner is a prick. He's trying to make a living and feed his family, not run a Coop bike shop. Not to mention the number of times I've heard of my own LBS guy "lending" a tool to even a regular customer only to get it back broken in some way.
Maybe ask the owner what tool do you need to do the job yourself. Maybe buy the BB from him and then do it yourself at the house.
maybe buy the BB and have him install it for a nominal fee. Just test to see how helpful he is, if not helpful take yer business elsewhere.
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
If you plan to wrench/really be a DIY bike guy, you need to buy the tools.
Quoted: 7348 Post(s)
Liked 2,470 Times
It's worse than that. Frying ham and eggs is very unlikely to ruin any expensive equipment. Wrongly used bike tools can break easily.
