Replace front derailleur on older Trek 820
Can someone tell me what would be a current, inexpensive front derailleur to replace the Shimano 200GS on my mid-90's Trek 820?
Thanks!
Thanks!
Someone in the Bike shop you go into, can see, I cannot.
why? they often just need oil, and are blamed for problems the control cable creates.
Still learning
While you haven't described the symptoms, if it's not a slack cable, or derailleur stop adjustment, my money is on the piece-o-crap grip shifter. I had more than one left side grip shift fall apart in my hands on vintage entry level treks.
A replacement 3 speed SRAM grip shift is about $18 + installation, or DIY. If you have an REI nearby, they may have one. Or get a 3 X 7 set of Shimano Tourney trigger shifters and put the problems behind you, also about $18, but then both FD and RD will shift more accurately.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
If you are sure the problem is the derailleur and not adjustment issues or the shifter, Shimano Tourney/Altus is the cheapest, but I'd go with Shimano Alivio for another $10-$15, just better quality all around. The good news is that lower end MTB FDs are relatively cheap. I just put a Shimano Deore 9sp FD on my Trek 700 for $20 purchased at my LBS.
Ludeykrus
Bicycle Mechanics
8
11-27-15 02:19 PM
