Bike Friday stem screw?
Bikes: Salsa single casseroll/Townie7d
The little screw that is by the lever near the headset nThat is removed when folding eeds replacing and I need to know if it can be purchased at a hardware store? If it only goes in partially is it ok to ride until replaced?
weirdo
I`m not clear exactly what screw you`re talking about, Commutenow. You mean the quick release lever to remove the stem? If that`s it, there`s no way I`d ride it without being able to clamp it tight. You can probably find one of those at a bike shop (seatpost clamp screw and lever if you can find one the right size). Alternatively, you should be able to replace the QR with a straight bolt. My 2012 Pocket Llama has a built in 8mm nut on one side, so I was able to ditch the lever contraption with no mods or extra parts. If you mean a different screw (headset lockscrew, maybe?) can you post a picture of it?
Location: Vancouver, Washington and Ocean Shores, Washington, USA
Bikes: 2 - 2007 Custom Bike Fridays, 2 - 2009 Bike Friday Pocket 8's, Gravity 29'er SS, 2 - 8-spd Windsor City Bikes, 1973 Raleigh 20 & a 1964 Schwinn Tiger
I think you referring to the 1" long, Hex Screw that takes a 5mm hex key to loosen/tighten - it allows the stem riserheight to be adjusted. Yes, it is a standard item that a good ACE Hardware Store should have in stock.
Why does it need replacing? (The one on my NWT is 5 yrs old, was adjusted twice when the bike was new, and hasn't been touched since.)
Lou
Lou
Thanks I have it figured out. I can see that this forum has a terrific amount of knowledge.
The man that sold it to me is sending me the 5mm(diameter) x .8mm (thread pitch) x appr. 9mm (under head lenght) metric socket head cap screw. It is located above the lower part of the headset near the lever used for folding.
