Flipping the stem
Flipping the stem
Ive heard flipping your stem all over this forum but I have no idea what it actually means. Could someone shed some light? I would ask this on the road cycling section but most of them are prentenious ******** and would never answer me.
Also slamming your stem is another one that I always hear but have
No clue about.
Thanks
No clue about.
Thanks
ouate de phoque
Bikes: Bianchi, Nakamura,Opus
Good one, I always wonder when I read this. I'm guessing that it mean putting your stem on the other side, angle down, so that the handle bar will be lower. But again, just guessing.
I'll further speculate that the reason is to gget more aero. On the other hand won't tthis cause more sstress on the wrist and hands? Hopefully someone can jump in here.
This thread should be used for all the terms experienced cyclist use tthat newbie don't understand lol. How bout when someone says they put out 300 watts. What the heck are they talking about?is riding a bike a new form of alternative energy or something?
Señor Member
Bikes: CAAD10CAAD10CAAD10
Stems usually have some amount of rise, usually a few degrees (they aren't perfectly straight.) Flipping it means literally flipping it from the stock position (which is usually the relaxed position where it raises the bars) to the position where it lowers the bars. Slamming the stem is removing all of the spacers from between the stem and the headset and putting it in the lowest position possible. It does usually make your position more aerodynamic, and yes, less comfortable. Once you're comfortable on a bike though, you can make adjustments like that with it still being rideable.
And Aeolis, watts are simply the SI unit for measuring power. When you're pedaling a bike, you're producing power, and buying a power meter to monitor your output is one of the best ways to train.
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6766 Post(s)
Liked 5,478 Times
^^^Yes. Of course this is possible only with a threadless steerer. The rise on quill stems is fixed only the height is adjusted.
And I disagree about the comfort. After I flipped my stem my ride was more comfortable. I still have some spacers under it so I haven't slammed it.
Sorry I don't have a shot with the stem in the non-flipped position.
Artificial Member
Liked 5,478 Times
Here's a video you may find interesting.
Cobb can be a little extreme but what he says is correct. Rotate your pelvis forward and use your back to take weight off your hands for comfort on the long haul.
ouate de phoque
Originally Posted by ahsposo;14601248
[IMG
[IMG
https://i871.photobucket.com/albums/ab280/ahsposo/Bianchi928_001.jpg[/IMG]
Man I can't figure out how to lower the stem and or take off spacers. I took both bolts off with Allen wrench but this thing won't budge!
Artificial Member
Liked 5,478 Times
Bikes: 2012 Specialized Sirrus
Quoted: 8 Post(s)
I went through a similar search, and didn't find anything, so I put up a post:
https://www.bikeforums.net/showthread...pping-the-stem
Necassary. My bike is already aero according to the name but this won't hurt. Hopefully this will shift some weight to my arms as my butt has been killing me on mmy new bike. I'd out the giant ssaddle on it but then the colors won't match up
Quoted: 1572 Post(s)
Liked 643 Times
Ha wow I'm an idiot. Thanks all set now. Gonna just slam it for now and flip it later if I feel it
1. Position your stem and any spacers. LEAVE THE STEM BOLTS LOOSE.
2. Install the top cap. Tighten the top cap bolt so that both:
A. if you rock the bike while lolding the front brake you don't feel a tick.
B. If you lift the bike the fork will flop by itself side-to-side.
3. Now make sure the handlebar is aligned with the front wheel and tighten the stem bolts. Alternate and walk them down a little bit at a time. Then need to be snug but they don't hold the whole bike together.
Artificial Member
Liked 5,478 Times
^^^Excellent advice.
Señor Member
Also, if you're new to the road cycling game, I wouldn't go changing anything without getting some fit advice- it's easy to look through the picture threads and stuff, but a lot of the guys there with super-aggressive positions didn't start anywhere near there.
Artificial Member
Liked 5,478 Times
Or noobs that don't have an attitude like you, and respectfully ask for advice, get it. Supposing of course their question makes any sense.
Ha well I just assumed they wouldnt bother with such a basic question. Don't really have an attitude and I'm glad I asked it here as everyone's been very helpful.
So if you're older and not so flexible, how do you get past the neck pain from looking to see where you're going when you ride in such an aggressive stance?
Artificial Member
Liked 5,478 Times
I'm 60y.o. and don't ride as aggressive as this video by a long chalk but I do have my hips rotated forward enough so my back is flatter and weight is off my sit bones. I am probably more of a "B" style back. I started riding like this in my early 40's and it made a lot of difference in my long distance comfort. It did take some getting used to and some effort to change my riding habit.
Something you have to realize about this style is that you use some of your back's inflexibility as kind of a spring to take weight off your hands. It's your lower back that will really talk to you at first when you get this right but as you adapt it gets real easy.
Bikes: Specialized Allez Sport
Quoted: 12 Post(s)
Generally speaking, you don't. Hip flexibility can be improved a bit but neck's, not so much. It's specially worse for shorter people because they are already low on the saddle to start with.
